Rear wheel Migrates to the left
Old 12-08-19, 09:41 PM
alanf
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 69 Post(s)
Liked 18 Times in 12 Posts
My roadie rear wheel migrates to the left after awhile and sometimes slightly rubs the lower tube that goes to the rear axle.
My guess is that this is from hard cranking going up a local hill and age (2000 model)
My guess is that maybe the wheel would benefit from having the spokes adjusted to bring the rim a bit right.
Any other suggestions?
alanf is offline
Old 12-08-19, 10:07 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1197 Post(s)
Liked 380 Times in 290 Posts
Tighten the QR skewer more firmly.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 12-08-19, 10:14 PM
ramzilla
ramzilla's Avatar
Quoted: 671 Post(s)
Liked 247 Times in 196 Posts
I put a set of new wheels on one of my bikes a few years ago. The wheels included new quick release skewers. The skewer on the back couldn't produce enough clamping power to keep the wheel straight when I climbed out of the seat and stood up to pedal up hills. I had to discard the cheap new skewers and buy some good old fashioned chrome steel skewers. The new steel skewers produced far greater clamping force & solved the problem.
ramzilla is offline
Likes For ramzilla:
Old 12-08-19, 10:40 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2620 Post(s)
Liked 742 Times in 552 Posts
The difference between enclosed cam and open cam QR units is a frequent topic here. So to is the axle extension beyond the lock nut WRT the drop out's thickness and does the QR bottom out bon that axle end. Broken axles is another common topic that can cause wheel shift during riding. Spokes that self loosen while riding (to allow the rim to shift over) yet somehow retighten before the beginning of the next ride isn't a common thing Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 12-09-19, 12:23 AM
alanf
Quoted: 69 Post(s)
Wow, Great info everyone. Really appreciated! This has been on my mind to ask the experts here for awhile.
alanf is offline
Old 12-09-19, 10:42 AM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 380 Post(s)
Liked 132 Times in 101 Posts
Another item to check is that the dropouts (the ends of the frame that the wheel clamps into) are spaced and aligned properly. If you haven't changed wheels or been in an accident, this is probably okay.
andrewclaus is offline
Old 12-09-19, 04:23 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 1815 Post(s)
Liked 561 Times in 399 Posts
Definitely recommend you check this, but it depends on the bike as to whether it might have come out of the box like this. Not uncommon for older bikes to have fork tips and/or dropouts not correctly aligned. Production has become better about QC items like this.
thumpism is offline
