'Squishing' Noise at Low Pressures
Bikes: 1977 Tom Kellogg Nr. 27 - 1984 Bob Jackson - 1987 Alpineer - 1999 Bianchi - 2002 LeMond Buenos Aries- 2007 Specialized Tarmac Pro - 2017 Mongoose Argus Comp FatBike - 2024 Gravity 29er 1-Speed Monstercross
Quoted: 67 Post(s)
Liked 290 Times
My tires have developed an annoying 'squishing' noise when riding. At first, I thought there was tar or some other sticky substance on part of the tire tread (I was riding on pavement). That's not the case. The tires are clean and the same noise occurs on the trail, regardless of surface. If I inflate the tires to 15-20 PSI, the noise disappears completely. Below about 15 PSI, it comes back. I'm guessing there is some movement between the tire and tubes causing the noise??? Is this noise common at low pressure?
Quoted: 969 Post(s)
Liked 1,632 Times
Likes For zandoval:
Quoted: 242 Post(s)
Liked 456 Times
What tires?
Why so low a tire pressure?
Likely, as previously stated, sidewall sound due to low pressure and movement.
Solution...already stated...
Likes For UnCruel:
I had one ride following a trail, but the last part was washed away. What should have been a 5km trail turned into a 25km road. It was a long day, quite tired, so I pumped up to 25 psi for an easier, bouncier ride home
Bikes: Trek Émonda SL 5, Trek Checkpoint SL 5, Giant Trance X 2, Trek Farley
Quoted: 81 Post(s)
Liked 97 Times
I have a pair of Origin8 Supercell tires left over from when I was riding a 26" fatbike. They exhibited awful self-steering unless inflated to the full 20 PSI. They're heavy, too, but they are the quietest fatbike tires I've had for pavement.
Likes For UnCruel:
Quoted: 67 Post(s)
Liked 290 Times
Low pressure (5-10psi) was initially for riding in sand. On the trail, I started at 20psi, but it was too bouncy in many sections and I lowered it to about 15psi. 20psi seems great for pavement but I don't really ride it on pavement.
What I've noticed is actual diagonal 'stress' lines on the sidewalls that were not there when I bought the bike. Bike was used but had been stored unused in an air-conditioned storage unit for 4 years. So I'm wondering if the tires (or at least the sidewalls) have become slightly brittle from age?
These diagonal lines were not there when I bought it. They are around most of both tires. Since I'm converting it to tubeless, I suppose I'll find out if this is an issue caused by the tubes soon enough.
Quoted: 559 Post(s)
Liked 648 Times
a MUP connects several trails in my area, so when on the paved I get to deal with the
wirrRRRRRrrrrrRRRRRrrrrrRRRRRRrrrrrr in time with my cadence.
On the bright side, walkers and runners know I'm coming... 500 feet away (slightly embarahassing)
(I sound like an off road 4x4 pickup)
(same lines that the dragsters get)
I've noticed that gumwall tires have the colorful layer that goes bad sooner for some reason (or it's more noticable)
I know that the cheapie knobbies (like the set I have) are heavier/more rolling resistance/more self steering.
But my cheap a- um... butt, gets buyers remorse if I get new tires before the old ones ware out.
I'm due for a set of jumbo jims.... so... one of these days.
Edit: apparently there is a sale and my cheap self just bought a set.... so update in a week or so.
Likes For CrimsonEclipse:
Quoted: 67 Post(s)
Liked 290 Times
Wow, the stress lines got significantly worse after my trail ride this morning They may have nothing to do with the 'squishing' sound - I really think that is a tube-tire friction problem. But I'm fairly certain the lines are cosmetic in nature and related to their age (6 years). I was running about 12PSI on the trail today and that seemed optimal. Started out at around 18 and the bike was nearly unrideable.
Quoted: 67 Post(s)
Liked 290 Times
Did I say 'cosmetic'? After a post-ride inspection, these tires are pretty much shot. The 'gum' is brittle and flaking away exposing the reinforcing threads. Looks like new tire time soon!
There have been some negative stories about gum wall tires. I only lightly skimmed over the stories, but it's a real thing
Quoted: 67 Post(s)
Liked 290 Times
Found this on MTBR forum:
there is a reason carbon black is added to rubber for tires, it has the highest
molecular surface area for reinforcement of the polymer chains.
it improves its tensile strength and wear resistance
skinwalls are weaker, since there is far less reinforcement and wear resistance going on in the non-black rubber
in fact any other color than black is weaker or the tire behaves worse in some way.
run them if you want, expect them to degrade sooner
Practically all rubber products where tensile and abrasion wear properties are crucial use carbon black, so they are black in color. Where physical properties are important but colors other than black are desired, such as white tennis shoes, precipitated or fumed silica has been used as a substitute for carbon black in reinforcing ability.
Traditionally silica fillers had worse abrasion wear properties, but the technology has gradually improved to a point where they can match carbon black abrasion performance.
advanced fillers are not in your gumwalls, your gumwalls are closer to raw vulcanized rubber.
I won't be buying gumwalls again for sure. Merlin in the UK has a clearance sale on Jumbo Jims - looks like just over $100 for a pair including shipping to USA
Likes For cegerer:
You also said the tires are six years old.
How were they stored? The way they were kept could have massive implications on that degradation.
I've had road tires (that weren't even gumwall) harden significantly after six years, and perform poorly enough that it was better to swap them out.
Quoted: 67 Post(s)
Liked 290 Times
Problem solved, sort of. After researching the subject on this forum and elsewhere the 'gum' is simply a weatherproofing that protects the threads. So it's not really structural. Applying a latex coating is all that's needed. This is one recommended product and what I used. Just brushed it on. 2 coats in those areas that were really bare. We'll see how they hold up. I've also got some Jumbo Jims incoming and will wait to go tubeless when I eventually mount those.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 191 Times
Likes For Viich:
