Riding terrain,What terrain characteristics you ride on?
Mainly Downhill Focused? Or Mainly Flat?
What kind of Wheels more suitable?
Brand: Trifox
Model: RW100
Type: light weight wheelset
Style: Quick Release
Material: Toray T700 Carbon Fiber
Depth: 38mm/45mm/50mm/60mm
Let's discussion together!!!
Brand: Trifox
Model: RW100
Seat Sniffer
Quoted: 945 Post(s)
Liked 2,008 Times
For me, climbing and downhill ... not a lot of flat.
Personally, I prefer wheels that are reasonably light, non aero, and if they have bladed spokes, only lightly bladed. Reasonably light for obvious reasons. Non-aero because that minimizes weight at the periphery and reduces the moment of inertia around the rotational axis, and also makes them more stable in crosswinds. Non-bladed spokes for the same reason (crosswind susceptibility).
I've had some bad experience with rear hubs in the past, so for that ... conventional and robust design is preferable.
Likes For Biker395:
Quoted: 827 Post(s)
Liked 1,967 Times
After popping a few spokes and cracking my Fulcrum 5 rear rim, I needed something more robust at 205 lbs and most of my rides are a minimum of 100 feet of ascent per mile on rough pavement.
I had prowheelbuilder build up a pair of Ventus 31mm deep alloy rims with 28 hole front and 32 hole rear and Sapim Race Round Double Butted spokes on White Industry hubs. So far so good. Not fast by any means, but I wanted something that would last without mechanical issues.
Likes For CAT7RDR:
Quoted: 6252 Post(s)
Liked 4,853 Times
Constantly rolling terrain. 4 - 6% grades and typically just 30 to 50 feet of elevation change with each climb. And for the most part fairly smooth asphalt or concrete. Though I do have to avoid cracks and potholes.
Round wheels I suppose. <grin>
I've never had any problem with my Belgian Weinmann rims and Normandy high-flange hubs. I try to ride as flat as possible, but I live in the mountains.
just another gosling
Quoted: 3901 Post(s)
Liked 1,953 Times
Hills and mountains, 50'-120'/mile. I build my own wheels, somewhat aero alu rims, CX-Ray spokes.
Results matter
Results matter
Likes For Carbonfiberboy:
Bikes: yes, i have one
Quoted: 1146 Post(s)
Liked 1,187 Times
i like going down. but first i have to pay by going up. my wheels are boring rim brake non-aero alloy relatively new.
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
Well, I have wheels for riding just about everything because I ride everything…….except single track. Both rim brake and disc. Regardless I always opt for lighter weight and durability over aero. Except for time trial wheels. Those are all about aerodynamics for me. All my wheels are clinchers with tubes, although I have a few wheels that could run tubeless.
Ride your Ride!!
Ride your Ride!!
Likes For jppe:
Quoted: 1069 Post(s)
Liked 788 Times
Yesterday's ride was to celebrate my 72nd Birthday, statistics follow >>>
Distance = 101.08mi, Moving Time = 6:33:08
ELEVATION = 62ft Kind of FLAT terrain
Likes For OldTryGuy:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2611 Post(s)
Liked 5,729 Times
Likes For rsbob:
Quoted: 1760 Post(s)
Liked 1,292 Times
Where I ride is mainly farms but with hills and usually wind. It can be anywhere from 60-80 ft/mi of climbing. My Mavic USTs do well.
Quoted: 1864 Post(s)
Liked 665 Times
I've always had trouble understanding how if I like to go down the hill, I don't also have to go back up, to where the car is parked.
Quoted: 935 Post(s)
Liked 1,327 Times
Flat...what's that? Around here every ride averages about 100' elevation gain per mile, often more, occasionally less. There is little choice in the matter. I'm not sure what wheel type has to do with terrain. Everybody wants light, but durable is more important for long rides where there's no cell coverage or easy way to get home.
Hugging the sea with mountains all around. Generally rolling if following the few and limited roads around the sea. Wicked climbs if go into the mountains. Alloy wheels.
Mike
Mike
Old Worn Treads
That describes my rides, too, although my climbs, when I WANT THEM TO BE, are longer with more elevation change. And I can vary my rides and have easy days 95% flat with just one climb.
Mavic OP wheels. Preferably round.
Old Worn Treads
But what was weather? Down in Florida was it 95 degrees and 95% humidity? That would make it harder than a hilly ride in 70 degree weather.
Liked 788 Times
Clear -- Temperature 83 ℉ -- Humidity 69% -- Feels like 89 ℉ -- Wind Speed 4.2 mi/h -- Wind Direction SE
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 415 Post(s)
Liked 950 Times
The valley is about 35 miles long, with minor elevation changes. There are mountains all around. I sometimes ride in the foothills, but not the mountains, so far. Mostly on 36-spoke wheels, either old, or brand new. All have tubes, and sealant, here in goathead-land. I do ride my tubulars on occasion. They have sealant, too!
Quoted: 4560 Post(s)
Liked 2,803 Times
It's all rollers here, with short, steep hillettes. And often very gusty.
I'd prefer classic 1980s-style low profile hard anodized rims, but those tend to need truing often and crack at the spoke junctures after several years. High profile aero rims catch air, which can be distracting on rural highways while negotiating pavement with passing vehicles, rough pavement and gusting wind.
So I prefer moderate profile rims for strength and low maintenance. I'm not a strong enough rider to notice any differences between rim designs, aluminum vs carbon fiber, or wheel weight, so I prefer durable rims that don't need constant attention, and supple tires for comfort. Nowadays, that seems to be mostly older Mavic rims I've acquired used from various sources. They've held up longer than the low profile, lightweight Araya CTL-370 and Wolber Super Champion Alpines (although I still prefer the looks of those classic low profile rims).
feros ferio
Quoted: 1395 Post(s)
Liked 1,336 Times
I thrive on hills -- always have. At 145lbs and 5'8" I am neither big nor particularly strong, but I emphatically favor traditional wheel designs, with at least 32 spokes in a 3-cross pattern, for reliability and tuneability.
I am far more interested in how fast I can ascend than in how fast I can descend, so I use the brakes a lot and don't bother with any gearing above the mid-90s of gear inches (50/14, 46/13, etc.).
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
In Tasmania, we have hilly or Tasmanian flat.
Tasmanian flat is something like this, or pretty close to it.
On a 50 km ride, there will be 500 metres of climbing.
On a 100 km ride, there will be 1000 metres of climbing.
On a 200 km ride, there will be 2000 metres of climbing.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
