Campagnolo 13-26 6SPD freewheel
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
TT Disc wheel take-off. Used, I guess, but looks sweet. 26 tooth cog had some filing(?) done, see pictures. $275 shipped
Campagnolo 7 (Seven) speed freewheel. Typically, 2nd cog is steel.
Spotless
Please note profiling(?) on back of 26 tooth cog. I left a bit of the original Campy grease.
Spotless
Last edited by Last ride 76; 05-30-19 at 11:42 AM. Reason: It's a 7 (seven) speed freewheel...
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Sorry that the description and price are below the first photo. Tried to change it.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Make sure you have the proper remover. I've seen too many of these with damaged remover slots from using the wrong tool. The official Campagnolo tool is jaw-dropping expensive, but Bicycle Research and Kingsbridge made affordable versions:
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Good point, John. As this is the only Campy freewheel I possess, I will include the proper BR remover as part of the sale. Just look at those clean notches,
Quoted: 834 Post(s)
Liked 2,125 Times
Oh, that's nice! Seldom seen with this cog range. I want it..just can't justify it. Good luck with sale.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Just curious, because I've never worked on one of these, does the body contain three pawls instead of the normal two? Specifically I'm looking at the underside and those three sets of holes (one large with a small tooling mark next to it which I assumed is to hold the pawl spring.
Any and all insights appreciated!
Bob
Bob
Bikes: 1971 Gitane TDF, 1974 Gitane Interclub, 2001 Serotta Rapid Tour CS3, 1986 Bruce Gordon touring bike, 1972 Gitane Super Corsa, 1978 Michal Johnson, 1972 Lambert Professional Grand Prix, 1983 Vitus (resto project), 1972 Raleigh Professional (resto)
Quoted: 43 Post(s)
Liked 34 Times
Boy oh boy! That must be a fast freewheel!
I know that these forums should remain commercial free but Pastor Bob is my hero! He restored a gloat of messy freewheels that are now the envy of the neighborhood. We need more of these C&V enablers to keep the rubber on the road and not at the landfills so give him good info - thx!
Old fart
Liked 3,400 Times
https://www.os2.dhs.org/~john/catalogs/campy-fw.pdf
Freewheel Medic
Liked 2,195 Times
John, thanks so much for posting the link to this PDF. After reading it I'll tell any potential clients with a Campy freewheel that I can't service one (unless I somehow stumble across the elusive special tool set--- for cheap)!
Actually, there are just two pawls which is standard for most freewheels. See page 7 which tells about the use of "Spring #7 " which compresses the pawls for reassembly.
After reading the manual I believe the three holes in the underside are to engage the special tool which prevents the body from freewheeling when removing the sprockets and servicing the internal parts.
Bob
Bob
Old fart
Liked 3,400 Times
Amocat223
15
08-23-18 02:27 PM
9volt
Classic and Vintage Sales
0
03-07-18 08:44 AM
