Brake levers
Brake levers
Old 04-24-06, 08:06 PM
Siu Blue Wind
Homey
Siu Blue Wind's Avatar
Quoted: 2425 Post(s)
Liked 1,399 Times in 894 Posts
Brake levers
Do you prefer an early grab or late grab when applying your brakes? Why?
Originally Posted by making
Please dont outsmart the censor. That is a very expensive censor and every time one of you guys outsmart it it makes someone at the home office feel bad. We dont wanna do that. So dont cleverly disguise bad words.
Siu Blue Wind is offline
Old 04-24-06, 08:11 PM
Pheard
Any grab, is good grab for me.
Pheard is offline
Old 04-24-06, 08:12 PM
Maelstrom
Wood Licker
Maelstrom's Avatar
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
I like a late grab. As close to the bar as possible. It allows for more modulation. Kind of hard to explain but I have it set so I have it partially pulled pre-engaged. I can nudge my finger slightly and it will brake.
Maelstrom is offline
Old 04-24-06, 08:20 PM
vw addict
vw addict's Avatar
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
I perfer them to grab in the middle of the throw to the bar. To soon is to twitchy, to late is
vw addict is offline
Old 04-24-06, 08:28 PM
Blazinall91
Show Me What'cha got
Blazinall91's Avatar
Bikes: old school Giant Attraction MTB (where it all started),old school Schwinn High Plains MTB (XC and long ride duty), Mosh DJ3 (BMX basher), and Trek Bruiser 1 (freeride and full of mods and still growing)
i like it in the middle were it won't pull much more without locking about 1/2 inch from the bar
Blazinall91 is offline
Old 04-24-06, 08:38 PM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
Don't make it too late or you will not stop fast enough in the rain.
2manybikes is offline
Old 04-24-06, 08:39 PM
Dannihilator
Still kicking.
Dannihilator's Avatar
Bikes: Bike Count: Rising.
Quoted: 159 Post(s)
Liked 46 Times in 32 Posts
I like an early grab.
Appreciate the old bikes more than the new.
Dannihilator is offline
Old 04-24-06, 08:41 PM
Maelstrom
Wood Licker
Maelstrom's Avatar
Quoted: 23 Post(s)
Depends, I half pull the lever all the time. Most dhillers run them the same way as well. Instead of having to pull on them I can just nudge them and have modulation and nudge a little more and I stop. All the while it is basically like my entire hand is still on the bar.
pinkrobe
DNPAIMFB
pinkrobe's Avatar
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
Mid-late on the front, mid on the rear.
pinkrobe is offline
Old 04-24-06, 08:42 PM
[bEn]
Just Ride
Bikes: 2005 Giant Yukon with the works.
Early-middle for me.
[bEn] is offline
Old 04-24-06, 08:49 PM
mcoine
early. 1 finger modulation at low speeds. both fingers for serious slowing at speed. I think it would help to mention what type of brakes you are using as well. I'm still on v's.. xtr. cantis and discs feel a little different.
mcoine is offline
Old 04-24-06, 08:54 PM
Siu Blue Wind
Homey
Hayes nine on the hardtail and squishy, Canti on the rigid steel, V on the Trek.
Old 04-24-06, 08:55 PM
Chone
I like a very short/close grab if thats what you mean, trials require you to lock and unlock the wheels constantly and well the rest is self explanatory.
I hope you mean what I think you mean.
Chone is offline
Old 04-24-06, 10:10 PM
Siu Blue Wind
Homey
I guess.....
For those of you who just put a choice, will you please explain why the preference? Thanks.
Old 04-25-06, 12:12 AM
leonardotmnt
With a later grab you also have more leverage. But like others said you don't want it too late or you won't have brakes
leonardotmnt is offline
Old 04-25-06, 07:24 PM
mx_599
Lost in the Black Hills
mx_599's Avatar
i demand early grab on my hydraulic brakes
reasoning:
during common braking, i want quick to instant results for my finger input. for uncommon braking (i.e. rapid decelerations, hard stops, and panic stops ), i do not want my lever to go much further than approx. halfway through it's range.
in my opinion, there is a point at which your grip strength, whether it be 1, 2, or all fingers, decreases through flexion. therefore, as stated above, i want hard braking to not cross the mid zone of travel where my finger strength to flexion ratio is greatest. there is a tension-length relationship for all muscles...fingers no different. furthermore, you never want to accidently have the lever meet the grip in a panic stop and not have your braking needs satisfactorily met.
this is my opinion and i will not waiver.
mx_599 is offline
Old 04-25-06, 07:38 PM
Siu Blue Wind
Homey
Makes a lot of sense, MX.................
Old 04-25-06, 08:22 PM
gmoneyhobbit
cptn. x-chains sidekick
gmoneyhobbit's Avatar
Bikes: stumpie, xtr, sid, ultimate sd
reasoning:
actually you have less grip strength with your fingers extended
i prefer a mid catch, when i say mid i mean that im both halfway through the lever stroke but also *moreso* halfway through the power of my brakes. i prefer this as to having an early catch because i still run v brakes, and like i said you have less leverage/mechanical advantage when your fingers are more extended, rather than being cupped in more.
gmoneyhobbit is offline
Old 04-25-06, 08:42 PM
mx_599
mx_599's Avatar
right you are gmoney
..and less strength when flexed. optimal strength is in the middle...exactly where i want my lever for strong stops. since i am using HYDRAULIC brakes, i do not need much strength at my extended fingers.
mx_599 is offline
Old 04-25-06, 09:57 PM
Maelstrom
Wood Licker
Maelstrom's Avatar
Quoted: 23 Post(s)
Ummm...hmmm...no...your hand fully compressed on a grip/brake lever the correct size would be optimum. Try a grip strength tester power lifters use, you would have very odd physiology if your grip is stronger half way out. I have grips (very large) that fit my hand and match the level to that so it is almost pinching the lever. If I move the lever out any further I do not have the matching strength
With smaller grips I definately need more of a mid range, but I dont run those anymore.
Either way, everyones personal point is moot. I tried a hundred different variations throughout three bikes until I figure out the best for me. I need two different setups, one for my left (missing fingers) and one for my right (large and complete ) Try everything and everythig until you find your own range.
Old 04-26-06, 04:38 AM
mtnbiker66
Old School Rad
mtnbiker66's Avatar
Bikes: Blur LT
I dont run brake levers.
Like a circus monkey on a stolen Harley......
mtnbiker66 is offline
Old 04-26-06, 07:25 AM
Dannihilator
Still kicking.
Quoted: 159 Post(s)
That must be apparent with his riding.
Old 04-26-06, 10:47 AM
gmoneyhobbit
missing fingers? how do you type?
Old 04-26-06, 11:19 AM
Maelstrom
Wood Licker
Maelstrom's Avatar
Quoted: 23 Post(s)
I have been typing since I was 6. I adjusted my typing accordingly. All I have is a pinky, an index and the thumb. All of which only have one knuckle (basically three thumbs). I type around 80 words a minute ...
Old 04-26-06, 11:34 AM
leonardotmnt
That's impressive Maelstrom. Maybe that's another weight saving feature weight weenies can incorporate?
