Rotation Limiting Headset Hunt.
#51
Quoted: 14 Post(s)
I use the VO wheel stabilizer on my 80s MTB set up in touring mode, it works perfectly for stopping the bars/levers from mangling the TT.
#52
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
Did anyone mention Velo Orange's wheel stablilzer?
https://velo-orange.com/collections/...eel-stabilizer
Or the venerable Rhode Gear "Flickstand"?
GearInches.com » flickstand
https://www.ebay.com/itm/153432289276
I've used the product Velo Orange sells. It's okay-ish, but doesn't really help if you have a load on the front end, or are trying to put a load (panniers especially, but also securing a load to the deck of a rack as well) on the front end. I considered replacing the spring with a lot stronger one, but instead have just reverted to using a strap the secure the front wheel to the downtube.
#53
Quoted: 39 Post(s)
But, it's big, ugly, and I'm not a fan of the protrusion sticking up like that though.
#54
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Have you seen this?
SteerStopper.com
#55
I'm going to give the VO option a try on a bike and see how it goes. Hebie also makes something similar, which I would try if they were available in Canada (seems to be mainly a Euro presence).
#57
Quoted: 1324 Post(s)
Liked 927 Times
For when I'm off the bike or working on a bike and want the front wheel to stay parallel to the rest of the bike I use an old toe-strap through the front wheel and around the downtube.
Cheers
Cheers
#58
I do the same thing with string/paracord/bungee - even when working on bike on workstand. It's a simple way to park a leaning, loaded bike to help prevent falling over. Even simpler, lay bike on ground in area protected from motor vehicle traffic (if it's clean/dry), then wind can't blow it over. Also, locking bike to a rack/sign/fence usually obviates the need for a special headset, kickstand or any other device. In a pinch, a U lock is a capable stealth weapon for self defense.
#59
Hello Snuts. Not sure if you (or anyone else) will see this message, but your pictures are no longer visible. I am super curious how you set up the velcro strap as a single-handed operation.
#60
Update:
I have been using the V.O. damper for a few years now. It's ok, but has barely enough tension to correct the front end even though unloaded and with the front end lifted up. This includes significantly tensioning the adjustment knob for greater tension. I would like to see V.O. offer this product in different native spring stiffnesses. Right now, the bars flop around far too easily. I think I might build my own, or remove the stock spring and drop a stronger one in there.
#63
Quoted: 626 Post(s)
Liked 399 Times
I currently use the Hebie Steering Damper 696 Universal
#64
I find the Acros Block lock excellent. All bikes should have such a device.
My other half was jealous, so I found that Decathlon also do something very similar: https://www.decathlon.fr/p/jeu-de-di...e/_/R-p-333414
So, you can add that one to your list.
slopvehicle
Bicycle Mechanics
6
06-17-13 08:42 AM
scionsound5
Bicycle Mechanics
4
03-22-10 08:53 AM
