Orange Seal seeping out of three holes in front tyre; worth fixing tyre?
Quoted: 800 Post(s)
Liked 512 Times
@2manybikes 3,700km on this particular tyre.
@Sy Reene Correct. I wasn't aware the manufacture of the tyre was up for debate. I would gladly have shared the information.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I was more curious about eduskator's tires, which are apparently made out of cheese.
What pressure are you at. It may have trouble sealing if the pressure is too high. Imo tubes are better if you are above 80 psi or so.
Quoted: 20810 Post(s)
Liked 9,456 Times
OS has no issues with holes that size at 80psi (or even 100, in my experience). I've only had one hole that OS didn't permanently seal, and it was recent - it was a 5mm/3/16" cut @ 75psi.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
That sealant looks like crap to me - watery, bubbly. Definitely not fresh - OS should look like slightly orange-tinted half & half, not.... that. Take off the tire, clean out the old stuff, put in new sealant - I bet they'll close. Tread looks like there's a lot of life left in the tires.
Liked 9,456 Times
IIRC, you made a practice of pulling and patching every time you got a puncture with Stan's because it wouldn't hold road pressures. That's crazy, IMO - I'd have given up tubeless in less than a season if that was my experience with it.
