Show Your Vintage MTB Drop Bar Conversions
#6551
The bike looks great. Those thumb shifters look very comfortable. Might be looking for those for my next project bike!
#6552
Quoted: 35 Post(s)
Liked 54 Times
The thumb shifter work indeed very well.
Of course, the place for the hand in some levers combination is limited near the stem.
But in 95% of the situation it is okay.
and the levers on the top was a request from my wife (never had a drop bar before)
It is about the only alternative to the levers+ Paul's mount I have found for a 24.6 mm bar (except of course some second hand parts I don't have).
The ratio price/function is excellent.
For the more common 31 mm bar , it doesn't work.
#6553
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Found this Marin at the curb last week and decided I need a racy rigid MTB and am using the conversion parts I was going to use on my Cimarron, and I'll do that bike later. No hurry on either one.
Likes For thumpism:
#6554
Liked 2,446 Times
Followup. Got it into preliminary shakedown configuration with some wider pedals and barcons (SunTour front and Shimano rear for later indexing). The rack braze-ons on the seat stays were packed with mud that had to be picked out and then the threads chased. One quick ride down the block and back shows stuff working. The original Marin Lite tires show no cracking but they do growl on our new asphalt. I still need some barrel adjusters for the front and rear hangers and need to sand or replace the brake pads. It'll be fun to see how useful this thing is but I'm already not riding my other bikes so adding another to the mix won't help things. Yes, the cables will be shortened and capped.
#6555
Laced up a cheapy $35 Shimano dynamo hub wheel and ran wiring for lights front and back. Front light is a Trelock with a stand light and an on-off switch that I picked up as a take off for $7. Currently using a vintage tail light, but have one with a stand light on the way.
Other changes include an XT M732 rear derailleur I had in the parts bin and a new made-from-scraps mudflap after the old made-from-scraps one that matched the front went missing in transit last week. Oh well, the new one is more fun anyway.
#6556
Quoted: 152 Post(s)
Liked 237 Times
Nicely done.
#6558
Bikes: '96 CAAD2 R300
Bikes: '98 CAAD 3 R300, '96 F600 Delta V, 2008 Specialized Roubaix, 2006 Bianchi M.U.S.S.
Why does everyone keep their stems so high when you convert to drop bars? Is it a geometry thing?
#6560
TXHC
So if I ride a 56cm road bike, a mountain bike with a 56cm top tube is generally going to have a seat tube measurement somewhere around 50cm and much more seatpost exposed. If I kept the stem low and used drop bars, the drops would be virtually useless (too low) and the hoods would probably be too far of a reach.
Thats my experience.
Likes For amillhench:
#6561
Liked 2,446 Times
Or, you could just be an old fart who can't bend over far or easily.
That's my case.
That's my case.
Likes For thumpism:
#6562
Likes For jlaw:
#6563
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
lol....wow!!
might be kinda hard reaching those shifters you go any lower, though....bahaha
#6569
Quoted: 1324 Post(s)
Liked 927 Times
#6570
Quoted: 4233 Post(s)
Liked 2,947 Times
Wow, that top tube is massive for that seat tube length. Or maybe it's just perspective. I don't think my mtb to drop bar conversion had that much difference.
#6571
Similarly, here's a profile view of my '84 Stumpjumper:
Although the top tube is huge, much of it is behind the bottom bracket; the actual stack and reach of the frame isn't too far off a road geometry for me. So by slamming the saddle forward on a zero-offset seatpost, I was able to do a road-ish fit without things getting very weird.
Likes For HTupolev:
#6572
Liked 2,947 Times
OK, I've only put drop bars on a late 80's Schwinn (many, many years ago) and an early 90's Mongoose (back when they were still a bike store brand), so maybe that was after geometries started changing a little bit (or maybe those were so long ago my memory is foggy).
#6573
1990 was NORBA era, MTB geometry got more road-like during that time. Since then, MTBs have moved back to very slack front ends, but the chainstays have remained short.
#6574
Liked 2,947 Times
Ah, that could be, my Schwinn Woodlands was a 1989 and the Mongoose was probably a 92 or 93 at the latest. They worked ok for what they were and were a decent gateway drug.
#6575
It has been a while since I've posted but this 1987 Street Stomper - it has gone through several changes. Here she is with Compass - now Rene Herse - Rat Trap Pass tyres:
I believe the next iteration will include moustache bars and a front basket.
