Internal Cable Housing Question
Quoted: 23 Post(s)
I am trying to put together a "new" bicycle, and here is my first (maybe not the last) problem
I am running internal rear brake cable through internal plastic sleeve inside the frame. The part of the plastic sleeve is exposed on the bottom. It runs half way between the cups.
As I understand it should be a cable housing installed between the end cups to cover the cable.
I cannot figure out how to install the cable housing so it will cover the exposed part of the plastic sleeve
See the picture:
2B1A0539 by Genna B, on Flickr
The cable is loose now. It will be close to the frame when housing is installed
Thanks
See the picture:
Thanks
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
The sleeve is meant to be used as a guide. Now that your cable is guided with the sleeve, rip out the sleeve, and insert the cable outer, cut to length
Quoted: 23 Post(s)
It I insert half of it, I am afrait it might create a clog where two plastic sleeves meet.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
That clear tubing is only needed to run the bare cable through the frame. (There's no internal channel to route it.) "Housing" is what the cable wire runs through, made of metal with a plastic coating.
I'm assuming the clear tubing was sticking out both the front and rear openings in the frame.
So:
Once your cable housing from the brake levers to the frame is cut to the correct length,
Push the cable wire through the tubing (already done, as your photo shows).
Pull the clear tubing right off the end of the cable.
Keep the tubing! (or the local bike store will have some.)
Now install the cable housing from the frame to the back brake. These brakes are down at the bottom bracket. Is there a pre-cut piece of housing sized for this distance from frame to brake, or do you have to cut it to length?
Later:
To change cables or pull the cable to change the front cable housing length:
Remove the crimp from the end of the cable wire.
Push the tubing onto the cable wire, then back through the frame, and out the front access port in the frame. You want at least a couple of inches of tubing exposed at both ends of the frame.
Hold the tubing in place and pull the wire out. Now you have a guide to push the wire cable back through.
So:
Later:
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
Yank it hard
Or actually it doesn't need to be removed. U could trim it so it doesn't clear the cable exit (so-called "cups")
Quoted: 23 Post(s)
So, do you mean to cut off the plastic cover that is there all the way to the cup?
This way the cable will be completely covered with housing, correct?
But in this case, if I need to replace inner plastic tubes/sleeves in future I will have no end to grab..
Quoted: 974 Post(s)
Liked 512 Times
yanking did not work, I cut off the black plastic cover and metal compression wire. I grabbed exposed inner plastic with wise grips, but it ripped off the exposed plastic part. The rest of the inner cable did not move
I don't understand what you are doing with the "black plastic cover and metal compression wire". It doesn't sound right. Post more photos, or perhaps take it to a shop.
Quoted: 23 Post(s)
but I still could not figure out how to pull out the plastic tube out of the brake housing
I was able to pull it out of the shifting cable, but not the brake cable.
and I probably need just the brake housing without the plastic sleeve inside, but it will not cone out!
Quoted: 6556 Post(s)
Liked 58 Times
ok, it is easy to do,
Once you have the plastic sleeve out reinsert the cable stops, cut a length of brake cable outer housing and insert this between the cable stops in the frame and brake. (Quick tip: Use proper cable cutters and insert spare brake cable into the outer housing when cutting to prevent crushing the housing). The outer housing will prevent the brake cable pulling straight between the two cable stops.
This picture might help. It looks like there is a quick release in the outer housing. I presume this is because the brake itself does not have a quick release. Placing a quick release in the outer housing allows the brake pads to be spread wider for easier replacement of the rear wheel.
I won't directly link the picture as it is very big:
https://raced.io/images/aero-chinese...mounted_bb.jpg
Quoted: 23 Post(s)
No, you don't pull out any plastic sleeve that is inside the outer cable (housing) either brake or shifter. That is supposed to be permanent for lubrication. The sleeve we are talking about is what was in the frame when you got it to guide the inner cable wires. There is some confusion here and several semantic issues. Please get in-person help at a shop.
I do not know the names of all the parts I am using
The inner plastic guide running inside the frame, and there is no problem with it
Then, there is a short piece of cable that runs outside of the frame. My problem to cover it the open part with housing
The problem is that the part of the cable is already covered by plastic guide/sleeve as you can see on the picture.
I was trying to install the housing over the cable without cutting the guide sleeve. That is why I wanted to remove plastic guide/sleeve out of the housing and slide up the housing over already existing guide, if it makes sense.
If not, I just probably cut off the plastic guide/sleeve that you see on the picture and install new brake housing over the bare cable.
Since I had no success to remove plastic guide/sleeve out of the housing, my questions are:
Is it possible to do it?
and if not
Should I cut off the plastic sleeve that is on the picture?
Thanks!
Quoted: 23 Post(s)
You should be able to use a pair of pliers to pull the cable stop (cup) out of the frame. You may need to do this on both ends. I wonder if the clear plastic sleeve is jammed into one or both of the cable stops as you shouldn't really be able to fit the plastic sleeve through them. This should allow you to pull out the clear plastic sleeve.
Liked 58 Times
Sorry for confusion
and if not
Thanks!
and if not
Thanks!
