Brake upgrade?
Brake upgrade?
After riding more I am starting to realize the brakes on my new Specialized Allez are not the best; I kind of expected this, as most reviews mentioned the brakes as a weak point. The current brakes on the bike are Tektro caliper brakes.
Just curious if I would need to upgrade both the caliper and pads, or if I could get away with throwing on some stickier brake pads?
Bikes: 2021 Canyon Endurace SL8, 2019 Cannondale Topstone Sora, 2002 Giant Yukon
Quoted: 34 Post(s)
Liked 148 Times
What's your budget.
New brake pads will be the cheaper first option, compressionless housing brake cable would be a second step and finally new calipers
I don't really have a budget, just looking for something with a bit more stopping power for around town (traffic lights, stop signs, etc.) If I can get away with just replacing the pads, that would be great.
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
Pads can be very expensive and probably won't do much if there is not good tension. Amazon has one v brake kit for 25 bucks and one for 40 bucks, both are all inclusive. I got the 40 buck one recently but it did't arrive yet. Should be adequate but if not then one shamino btr4000 brake for front or back is 15 bucks more, so still much cheaper than if you got all the parts separately.
This is a really good thread on the subject you're asking, lots of ideas - Shimano vs tektro road calipers
I also found the review that in cycling weekly that talks about how the brakes don't have good initial feel. The same review goes on to say the stock wheels are on the heavy side and your shifters are claris so tiagra might be an upgrade path - I added that last bit.
I think your frame has the carbon fork so the frame is shared throughout most of the lineup which means the frame is worth putting money into.
Make sure the brakes are setup the best they can be before needlessly throwing money at the issue.
I have a 2020 Allez Elite. I’ve owned it for maybe 2 months. About 2 weeks ago I took the Axis 1.0 calipers off and put on Ultegra calipers. They made a noticeable difference in stopping power as far as braking authority. I had little confidence in the feeling of the stock Axis 1.0s. Ultegra calipers feel so much better, I highly recommend them.
www.mp-aviation.com
www.mp-aviation.com
Likes For InvertedMP:
Quoted: 822 Post(s)
Liked 1,955 Times
Recreational Road Cyclist
Quoted: 255 Post(s)
Liked 252 Times
You might start with some Kool Stop salmon pads. If they don't do the trick for you, you can use them to improve whatever brakes you put on next.
Likes For BCDrums:
Half way there
Quoted: 986 Post(s)
Liked 879 Times
I've never had to do panic stops for traffic lights or stop signs. Are you saying that your brakes are not up to the gradual slowing required for these devices?
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Biggest changes would come from better pads and compression less brake housing (if that is not what you already have.
As far as getting new calipers, I’ve had Tektro, Cane Creek, and Ultegra calipers. Once they are all running good pads and housing, there is a performance difference, it is not all that much IMO.
I just got the bike a few weeks ago but am already loving it. I can definitely see upgrading to Tiagra or better in the future, but for now the Claris work perfectly fine for me.
Brakes were looked over by the bike shop and myself and seem to be adjusted well.
I should have been a bit more clear. I meant traffic lights and intersections in general. I ride in a city that is on a huge upswing and is getting busier by the day. I would just feel more confident with a little more bite if a panic stop were needed.
Thanks for the suggestions everyone. I think I will start with the Kool Stop Salmon pads recommended in here and then move on to the Ultegra calipers if needed.
Likes For bran1986:
