Sheet, Why always the rear clincher flatted?
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,828 Times
And while we are at it:
Why are road clinchers so fragile compared to road tubulars?
All tires square off, the rear because of your body weight. I always rotate front to rear to minimize.
If you are experiencing early wear change to a more durable tire.
Veteran, Pacifist
Liked 4,828 Times
I mostly roll tubulars - 2 rears for every front.
I get the same mileage out of my clinchers. Two rear tire changes (due to wear) for every front, barring sidewall cuts...
Oh, and I hit a piece of concrete road debris last week and got a 'snake-bite' puncture on the 28mm front that was 85psi. First flat for any reason in almost 15 years! Schtuff happens...
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
More weight, more friction, quicker tread loss. I think in the past 4 or 5 years, the only flats(2) on the front were when using a used tire, decent tread left, with latex tube. That was this spring when I had at least 12 flats in 2 months. Roads were loaded with debris, mostly from construction waste and road work. I usually get 1 to 3 flats per year. Last year I had zero in approximately 5000 miles. I guess the law of averages did some catching up.
