What's your favorite way to clean a chain?
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 77 Times
From time to time I read different approaches to cleaning chains. What's your strategy?
Quoted: 3015 Post(s)
Liked 3,805 Times
I occasionally wipe it with a rag.
When it wears out, I buy a new one at the LBS for $10.
Since they are so cheap, I won't go through contortions to clean it.
That is my strategy too.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,099 Times
Wipe it down every 2 or 3 rides, lube with White Lightning every couple hundred miles. I don't generally ride in the rain, so it never gets that dirty, but back when I commuted rain or shine, that same process worked well, just more frequent wipe downs.
Quoted: 1372 Post(s)
Liked 1,752 Times
I add Prolink lube, one link/pin at a time (carefully cause I am cheap). Then I wipe the excess (not really much excess) off with a rag. I clean between link plates, one at a time, with Q-tips (need several per cleaning), until the chain looks pretty good. Then...
I add more Prolink, to each pin, a drop or two at a time, ensuring that I get every pin lubed. Run the drive backward, hoping to draw the lube into the chain. Lube one more time, run drive backward and then wipe off the excess.
Been doing it that way for many years and, to date, only two broken chains. One on a Giant XTC and one on a Miyata 1000.
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
Lately I've done this, and been happy with the results...
I put slightly used Seafoam in a park chain scrubber and run it through for about a minute as a "cleaning step"
I have second chain scrubber (a cheapie version from a dept store) that gets newer Seafoam as the "lubricating step"
Quick wipe of excess and done. The Seafoam both cleans and lubricates, and is comparatively inexpensive for the volume used.
When the "lubricating" Seafoam becomes dirty, it goes in the "cleaning" scrubber. When the dirty Seafoam is spent, I toss it in with the waste oil for recycling.
Sounds involved, but it takes maybe 5 minutes to clean a chain to like new. They run quietly and smoothly, for a long time.
Uber Goober
You can get terrycloth washcloths at Walmart at 18 for $4 or so, which makes them basically disposable. So I rotate the chain while putting lube on it, rotate it around a few times, then take the washcloth and wipe about 8" at a time until the black gunk is off.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
+1 for a new one
When I worked as a bike sales rep I used to buy a box of Sedisports (10 per box) for $28 wholesale (as I recall). Every 1000 miles, just put a new one on, more often in rainy season.
Quoted: 129 Post(s)
Liked 77 Times
I guess I'm a little floored - no one cleans their chains? The consensus seems to be replace it when it starts to look dirty. I've always wiped my chain down after several rides; immediately afterward if it's been raining. I'd never imagined I would be in such a minority.
Cyclist
Soak it in simple green for an hour or so, wash off, dry in the oven, then relube. I've heard some people caution against using simple green, but I've never had a problem
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I have a Finish Line chain cleaner that I've used once. I'd like to use it more because it does a good job. But I don't take the time, usually. I wipe it down, or not, and put a drop of Triflow on each knuckle, let it soak in, and wipe it down again.
Liked 3,805 Times
But if it takes more than 2 minutes per month to clean the chain, I'm out.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 129 Post(s)
Liked 77 Times
Liked 2,568 Times
Yeah, I didn't figure you wanted to start a debate, and I find the subject interesting, too.
RUSA #7498
Originally Posted by noglider
Bikes: Numerous
Liked 3,099 Times
Yes, replace when its worn. This is probably my oldest chain (but not oldest bike!) in my stable at about 3000 miles, using the wipe and occasional lube method.
Quoted: 18379 Post(s)
Liked 4,512 Times
I pin my chains. So, once it goes on the bike, it stays on the bike until it is time for replacement. I'm trying to be a bit more proactive with replacing.
I'm of the wipe & lube camp. A little chain grease on it doesn't hurt.
Quoted: 835 Post(s)
Liked 2,136 Times
I thoroughly clean my chain every few months, but I let the ultra-sonic cleaner do most of the work for me. It may appear like a lot of steps, but none of these steps takes more than a few seconds. Total actual work time is close to iab's couple minutes every few months threshold.
1. Remove chain completely. (30 seconds)
2. Place in shallow tray or Regina chain tin with kerosene. (30 seconds)
3. Agitate & let soak for a couple minutes. (15 seconds)
4. Place in ultra-sonic cleaner. (15 seconds)
5. Remove from ultra-sonic cleaner and apply WD-40 to remove any excess water. (30 seconds)
6. Hang on hook and wipe dry. (30 seconds)
7. Re-install chain on bike. (45 seconds)
8. Lube with your preferred grease. (15 seconds)
I sill use some expensive vintage chains (Regina Superleggera hollow pin chains on a couple bikes, vintage Dura-Ace and Sedis chains, etc.) so it's worth it to me to do a little extra maintenance. I also use Regina freewheels, vintage chainrings, and Bullseye pulleys, so I do what I can to minimize overall wear. I like a clean drivetrain overall, as well. I think a bike looks best when you can see clean metal between the cogs.
Ideally? off the bike in a basket in Kerosene in a bucket . crud goes thru the basket and settles in the bottom of the pail.
Quoted: 821 Post(s)
Liked 255 Times
I get rid of chains on my off road stuff fairly quickly.
I do try to clean them after a heavy weekend of use.
Last thing I want is a chain failure in the middle of nowheresville.
As I wrote in the other thread, where I mentioned that you all might think I'm crazy!
I actually used gun cleaner on an old rag, and to oil the chain and freewheel, I carefully applied synthetic, water-proof, trombone slide oil from a spray bottle! Don't knock it... It is ultra lightweight and actually worked really well!
See post #8 below...
https://www.bikeforums.net/classic-vi...l#post18122556
Bikes: 1997 LeMond Reno, 1973 Gazelle T'dLA (retired)
Usually WD-40 and a rag
Every now and then if i need it thoroughly clean then chain tool and deisel in a tin can
