Shimano Alfine 11 speed internal hub for touring?
https://road.cc/content/news/13981-sh...-car-park-test
Specs are listed as follows:
* Gear range: 409%
* Weight: approximately 1600 grams
* Oil lube gearbox
* Silver only (initially)
* Price: approximately $420
* Due out September 2010
With a price at about a third of the Rohloff this seems like it might be a financially viable option to tour with.
* Gear range: 409%
* Oil lube gearbox
Why not? If people can tour on singles, this hub would be a huge step up. I don't have any experience with internal geared hubs but from what I've read, they are very reliable and the gearing is evenly spaced for efficient riding with a load. Shimano stuff is generally of a very high quality and while you can find comparable boutique parts for twice the price it doesn't take away from the fact that Shimano supplies probably the majority of the parts on any kind of bike being ridden today. I wouldn't hesitate to tour with this hub.
The gear range is a little narrow, but if you're not touring anywhere too hilly, or willing to give up some top end, then it could work. It would be nice to get some long term reviews to test reliability and such.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
To me the ultimate tour bike would be an IGH rear hub and a Schlumpf drive on the front I tour on my Raleigh 3 speed all the time, yes I walk up a few hills and coast down the other side. An 11 speed affordable hub would be great. I have a bike that I am planning a build up on using the 11 speed when it becomes readily available.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Location: CO....Hetchins MO, Merlin XL, Trek, Klien, Specialized, Kestral, Bataglin, Guerciotti, Bianchi, Schwinn, Colnago Geo, Miele, Contini, Feggin, Cannondale, Lemond, Ciocc, Giant, Rossin
Bikes: Hetchins MO, Merlin XL, Trek, Klien, Specialized, Bataglin, Guerciotti, Bianchi, Schwinn C19, Colnago Geo, Miele, Contini, Feggin,Cannondale, Lemond,Ciocc, Giant, Rossin
I like the idea but always come back that it would b e better to have a system that could be fixed anywhere.
That is why I went to bar end shifters. I must admit that now I am looking for some to use and get rid of the drop bar.
This user is a pipebomb
Bikes: Bianchi Volpe 2001, GT ZR3000 2001, Raleigh One Way 2007
Probably not rated for high enough torque for touring. Most internally geared hubs are not recommended for touring, or for hauling heavy loads, or for use by very heavy riders for that matter. I contacted SRAM when their imotion 9 speed hub was released, asking if it was suitable for touring. They told me that it was not. SRAM does make a 5 speed hub that is rated for high torques. I think it's called the Cargo, or something like that. But the gear range isn't anywhere near where you would want it for touring.
If you read the technical spec sheets for these hubs, you'll find that they aren't likely to be able to stand up to the forces that most fully loaded bicycle tours subject drive trains to.
Rohloff hubs are different. They are rated for higher torques. The Nuvinci CVT is rated for really high torques, like double what the Rohloff is. But the Nuvinci is a god-awfully heavy beast.
You could probably use this hub for light touring, but I wouldn't ever get into a situation where I was too far from a bike shop if I was using one.
5X heavier than a rear derailleur, 7X more expensive, still needs a chain, and it's impossible to fix/repair/replace should anything happen to it. Think I'll pass...
GATC
Climbing the last hill to my house today my chain jammed between the 2 small rings and again I was thinking 'boy an IGH would sure be nice right about now'
Acetone Man
That's like comparing a chevy volt to the battery bank on a prius; it would be substantially less disinforming to compare the IGH with everything that it replaces, at which point it is neither substantially heavier nor more expensive at the same Deore XT quality level.
You're right, the Alfine replaces a hub, derailleur, and cassette so we should look at the entire system... Deore M592 RD: $65 & 286g, XT M756 Hub: $44 & 302g, XT M770 11-34 Cassette: $70 & 297g. Adding it up: $179, 795g. Still doesn't seem that attractive...
I think IGH's make a ton of sense on folders or bikes with S&S couplers that are going to get packed and shipped a lot. Seems to me that you have less stuff to get knocked out of alignment (derailleurs, in particular).
Co-motion has been showing this Americano with Rohloff + disc brakes + belt drive:
https://www.co-motion.com/single_bikes/amerohloff.html
Would imagine some point they could do this with the Shimano Alfine.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Bikes: Balthorium G
It might be these new bifocals playing tricks on me but I haven't seen any spec sheet listing for 36 spoke wheels. Have I missed it?
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Liked 6 Times
My buddy and I rode the CDN GDR route last summer on Surly Pugsleys each running a Shimano Alfine 8 speed IGH. We carried camping gear, food and clothing for 5 days + water we topped up twice a day.
The hubs were flawless and the gear range was more than adequate for fully loaded dirt road touring. One day in particular was mostly uphill for 130kms with a mtn pass at the end. We each walked our bikes once or twice per day on the steepest climbs, but our walking pace was usually the same as the rider who stayed on his bike so no practical benefit to staying on the bike. Neither of us was in great shape or had done any mountain touring that year.
That same hub has been to Burning Man, Baja Mexico twice as well as lots of winter biking in Alberta. So far it has not missed a shift and continues to run flawlessly.
One big advantage for this setup is that in dirty, dusty, muddy, sandy conditions the hub just keeps on shifting perfectly and needs next to no maintenance.
Touring on a 11 speed Alfine won't be a problem. You'll get the most benefits from a IGH if you can skip the chain tensioner and run it in a frame that allows you to tension the chain another way [horizontal drop outs or eccentric BB]
As for reliability I'm doing everything I can to torture test my Alfine - so far it's been A+++.
BTW - if you want an expedition touring bike a lower cost look at the Surly Pugsley. Since the front wheel is also a rear drive wheel you can back up a cheaper IGH like an Alfine with a fixed gear or SS front wheel and not have to stress about an unlikely IGH failure. You can run a Pugsley with 29er MTB rims so you don't need to run 4" tires...XRs, Supremes would work great.
So far the shimano hubs seem to have proved out more durable than expected. The earlier 8 speeds were not supposed to be used offroad, but they proved out in time. I was more interested in the redline 8 speed when it came out. It was cheap enough to be a real Rohloff alternative. Not as good as Rohloff but would suit a lot of less demanding users at a far more reasonable price. At what the 11 speed costs, I am just as happy I picked up the Rohloff.
cyclopath
Liked 6 Times
Acetone Man
It has also occurred to me that moar bikes designed for IGH should be made to be carbon drive compatible, even if you're just using a regular chain. I'd much rather split a rear triangle to remove a chain than split the chain, or futz with some master link. And I'd much rather get the chain clean off the bike if I'm packing it in a suitcase to travel somewhere.
Haha, Vik. That Pugsley you have is awesome. You could run over a dinosaur with that thing
My buddy and I rode the CDN GDR route last summer on. We carried camping gear, food and clothing for 5 days + water we topped up twice a day.
Quoted: 261 Post(s)
Liked 11 Times
I think the Nexus 8 was a much better improvement than the Nexus 7 which felt like oatmeal was inside the hub! I still would like to know the lowest gear you can use with the Red Band 8 because we know those Rohloff hubs have been tested beyond the recommended torque levels.
Quoted: 261 Post(s)
Liked 11 Times
All the marketing of these hubs and that includes Rohloff state how a derailluer drive weights just as much. I never really did the math but I'm glad someone did! It was not my imagination how heavy that Nexus 7 felt and how it added to the weight of the rear wheel.
I still want a Nexus 8 though.
Touring - loving it!!!
Bikes: Thorn Raven Nomad, Mongoose Crossway 250, Ricardo, Revlin, Avanti
The above doesn't include the extra weight of the longer chain, the 2 extra front cogs, front derailleur, and the extra gear lever of a typical derailleur equipped bike - it's closer than what the above suggests.
cyclopath
Liked 6 Times
I am running a 32T ring with a 21T cog on my Pugsley's Alfine 8 - fully loaded MTN touring on dirt roads and offroad, technical MTBIng, snow biking. I have not been gentle to it and so far it's been perfect.
Unfortunately, you can't have your cake and eat it, too: if you want an Alfine-based system to have the same spread of gears as a derailleur based system, then it's going to need a front derailleur, chain rings, and shifters. Conversely, if you want the derailleur based system to be restricted the same span as the Alfine you can drop the FD or at least some of the chain rings.
