What are these handlebars?
Old 04-03-10, 12:03 AM
goodtosea
i want to swap out my drop bars for someting a little more comfortable. does anyone know what bars these are or any that are similar to them??
please!! and thank you!!!
goodtosea is offline
Old 04-03-10, 12:46 AM
rufvelo
rufvelo's Avatar
flat bars
rufvelo is offline
Old 04-03-10, 12:56 AM
alpha_bravo
Mr. Sparkle
alpha_bravo's Avatar
Bikes: 08 Specialized Allez Elite
Liked 5 Times in 3 Posts
Just take your drop bars, flip them, and chop them... Problem solved!
alpha_bravo is offline
Old 04-03-10, 01:37 AM
goodtosea
thanks! but then again no thanks...
Old 04-03-10, 07:40 AM
rufvelo
rufvelo's Avatar
Just take your drop bars, flip them, and chop them... Problem solved!...
This is a good idea, I will be doing this on my steel Bianchi soon.
rufvelo is offline
Old 04-03-10, 07:47 AM
Mos6502
Elitest Murray Owner
Mos6502's Avatar
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
Liked 3 Times in 2 Posts
Those are handlebars.
;D
But, I have heard them referred to as "French" bars, which certainly doesn't help much. I've seen them on a lot of older mixtes (and French bikes), but I feel like the catalogs called them "touring" bars, which also doesn't help much.
Mos6502 is offline
Old 04-03-10, 07:49 AM
X-LinkedRider
Flying Under the Radar
X-LinkedRider's Avatar
Bikes: 10' SuperiorLite SL Club | 06' Giant FCR3 | 2010 GT Avalanche 3.0 Disc
They are just commuter bars, not comfort bars. People mistake the two. You can find them on any 80's style or even 90's style commuter bike.
X-LinkedRider is offline
Old 04-03-10, 07:52 AM
Mos6502
Mos6502's Avatar
https://www.freemanscycles.co.uk/prod...rs%20-%20Alloy
hum :\9
Mos6502 is offline
Old 04-03-10, 11:41 AM
DubT
Bikes: Trek Speed Concept 9.9, 2011 Calfee Tetra Tandem
Quoted: 46 Post(s)
Liked 18 Times in 9 Posts
What is wrong with your drop bars, if you bike fit is correct you should be comfortable on the hoods.
DubT is offline
Old 04-03-10, 11:59 AM
bismillah
bismillah's Avatar
Yes, these are handlebars
bismillah is offline
Old 04-03-10, 12:02 PM
ptle
Liked 2 Times in 1 Post
If you change to flat bars you will have to get new brake levers and possibly shifters. What kind of bike do you have and why do you want to switch to a flat bar.
ptle is offline
Old 04-03-10, 10:45 PM
Jinker
Jinker's Avatar
Bikes: Univega Via Montega, Nashbar Aluminum frame/105 roadbike
If your bike is not comfortable, you likely have a fit issue. Flat handlebars will end up in near the same location as the tops of your drops. If you're not comfortable riding in that position, a straight handlebar won't cure it. If you get a riser bar, you'll have a more upright, relaxed position.
I would suggest talking to someone about a bike fit before spending a bunch of money to swap your bars, shifters and brake levers to possibly find that you still don't fit on your bike.
You may be able to fix the position on your bike with modifications, or maybe make it into a functional flat bar road bike, but there's a chance you won't, in which your best course of action is to unload the bike, and get something that fits you.
As to where you get some straight handlebars, or slightly curved commuter bars, your local bike shop should be able to help you. If they don't have them in stock, they should be able to order something for $15 or $20. They'll also be able to help you out with all the parts you'll need to swap your bike over to flat bar if you want. Also, they may have someone with experience fitting bikes who can tell you if your bike is a lost cause fit-wise or not.
Jinker is offline
Old 04-03-10, 11:14 PM
roadiejorge
stole your bike
roadiejorge's Avatar
Bikes: Orbea Orca, Ridley Compact
Quoted: 4201 Post(s)
Liked 27 Times in 18 Posts
This
I like pie
roadiejorge is offline
brian3069
2
07-22-11 01:26 PM
neocaligatio
Classic & Vintage
7
06-10-11 12:51 PM
Lilcphoto
Singlespeed & Fixed Gear
6
10-03-10 08:25 PM
Scrodzilla
31
01-23-10 06:43 PM
DavidARayJaxNC
Classic & Vintage
65
12-31-09 11:57 AM
