Want to help me pick a crankset? Having trouble
Bikes: '93 Cannondale T-1000, '03 Cannondale R800
Quoted: 21 Post(s)
I'm building a touring bike that I'm going to be using for commuting as well. I'm worried the crankset I want does not exist...
Here are my weird requirements
- triple
- approx. 52t outer chain ring
- 180mm crank arms
I was all set to buy an XT crankset. Then I saw that the outer chain ring is 44t, which is too small for my commute... There are stretches of my commute where I am riding 53t x 12t and need it.
As far as I can tell, there are no MTB triples out there with outer chain rings bigger than 44t. I would be okay with buying a decent MTB triple and replacing the outer chain ring with a bigger one... ::edit.. doesn't look feasible::
My other choice is a road crankset, but I can't find any road triples that have ~52t chain rings and 180mm arms.
- triple
- 180mm crank arms
you can get shimano triple with 52 outer chain ring or campag as far as i know .you could then change the rings to TA rings if you wish.
Look for a vintage MTB crankset with 50.4 BCD and use any TA rings you want.
The sugino supermaxy came in lengths of 165-185 and the 50.4 rings canme anywhere from 22 or so all the way up to ~62.
https://www.flickr.com/photos/24722971@N05/5291272913/
I found a supermaxy set in 185 at a bike coop for ~25 bucks.
given 11 t cassettes the current rage .. 44 is plenty big
velo Orange has 46/30 doubles
ask Lennard Zinn, his bike building company has 180 and longer crank arms available..
Settle for 175 and Campag race triples set up nicely with a 52 42, and sub the 30 for a 26T.
.. OR 50 40, 24..
.. OR 50 40, 24..
Does this do it?
https://www.davincitandems.com/comp.html#cranks
https://www.whiteind.com/cranks/mountaincranks.html
The Shimano Deore FC-M590 triple is available in 26-36-48 rings. If you can switch to a cassette with an 11-tooth gear, 48/11 will get you very close to 52/12. The longest Deore crank arms are 175mm, not 180 like you want either, although if you can detect a 2.5mm crank radius difference, you're far more sensitive than most cyclists.
If you plan to index shift the MTB crank, you know you need to use a road front derailleur and account for the wider default chainline, right?
Quoted: 21 Post(s)
I've decided to go with the 180mm XTs and deal with the loss of speed. Down the road might replace the 44t chainring with a 48t.
I appreciate all the suggestions. There are 180mm triples out there with bigger chainrings, but they're all in the ~$400+ range..
I was also crunching the numbers on a weird alternative set up.... getting a 180mm road double, setting it up with 50/34... then getting one of the newer 36t rear cogs. You can get gear inches around 25.7, and the 180mm crank will make it feel even lower. Not quite the 22/24 gear inches sheldon says most mtbs have, but it's something.
Interesting! I did not know that. I'm going to be doing bar-end shifters on this one... might get a road derailleur anyways then...
Edit: I say all of this on the assumption that you had planned to index shift the front with road STI shifters. If, in fact, you were planning to index shift it with MTB shifters, you'd need the MTB front derailleur.
Spearmin
Bicycle Mechanics
5
08-13-17 11:47 PM
interestor
Bicycle Mechanics
11
04-20-17 02:06 PM
noobinsf
Classic & Vintage
6
11-04-14 09:38 AM
mobi
Road Cycling
12
10-04-13 07:00 PM
