Going Tubeless: Any tips to help get the bead to stay against the rim?
Old 01-31-12, 07:42 PM
Lindenwood
I spent an hour last night trying to get any into my front tire after converting to tubeless. I eventually just put the tube back in for a ride today, but I got a flat (and had already used my spare a few days ago, lol), so now I really want to try to get it working Tubeless.
Does anyone have any advice for getting the tire to seat well enough against the rim to inflate? I tried soapy water and everything. Even with my garage compressor at 125 PSI, and just wooshes out everywhere. In a lot of places, there is barely even a tight enough seal to get bubbles!
Please help! I don't want to have to go buy more tubes when I just spent $30 on sealant, heh. Plus I want all the advantages of tubeless .
Thanks.
Lindenwood is offline
Old 01-31-12, 07:47 PM
electrik
Single-serving poster
electrik's Avatar
Some tire and rim combinations won't work.
electrik is offline
Old 01-31-12, 08:08 PM
Lindenwood
Arg! Hmm. The tires have very little wear so I'd hate to have to replace them already . But yeah the beads don't seem to want to press outward against the rim like they would when inflated.
Old 01-31-12, 08:10 PM
lunchbox1972
Bikes: 01 Specialized Rockhopper A1 and 07 Felt Z80 05 Canondale Prophet
You have to set the bead. In my experience if you have UST/TNT tires and UST wheels, you can use a hand pump. I have set the bead with a hand pump using a Stan's strip on a non-tubeless rim, it is a UST tire though.
If you have a compressor, you may need to use that to get a high enough pressure to pop the tire on the bead. I have found that I have to push down on the tire a bit, buy the valve stem, in order to set it with the hand pump..
Good luck!!
lunchbox1972 is offline
Old 01-31-12, 08:53 PM
Lindenwood
I am just using a "ghetto' conversion and the standard tire that came with my bike. I didn't even try inflating it with my hand pump, especially after my compressor (with tank) failed, heh.
Applying some pressure to the tire while inflating seemed to slightly reduce the amount of air that leaked past the bead, but a whole lot still escape (obviously, since it wouldn't ever inflate).
Old 01-31-12, 09:35 PM
Daspydyr
Pedals, Paddles and Poles
Daspydyr's Avatar
Bikes: Santa Cruz Tallboy, Ridley Noah, Scott Spark 20
Quoted: 1233 Post(s)
Liked 69 Times in 58 Posts
Same thing happened to me. Stan's says it supposed to work with any tires, but it didn't work for me, or the guys at REI!
I think its disgusting and terrible how people treat Lance Armstrong, especially after winning 7 Tour de France Titles while on drugs!
I can't even find my bike when I'm on drugs. -Willie N.
Daspydyr is offline
Old 01-31-12, 09:47 PM
Lindenwood
Dangit . I am going to probably try one more time with these tires and then maybe look into getting some new ones.
Do UST tires help even without UST rims?
Old 02-01-12, 12:42 AM
born2bahick
Official Website Waterboy
born2bahick's Avatar
Bikes: a lot
i have a trick i use for stubborn tires. Go to the hardware store and buy a squeeze bottle of slime tire sealant. Squeeze a liberal amount all the way around the bead/rim on both sides, let set a few mins and put the air to it. It's messy, go outside the garage to air the tire. One big bottle of slime will set up to 6 sets of tires so it love you long time.
born2bahick is offline
Old 02-01-12, 01:01 AM
mechBgon
mechBgon's Avatar
Liked 6 Times in 5 Posts
Also try this:
1. put the tire on with a tube and air it up. Tada! both beads seat.
2. carefully remove the tube by breaking the seal on only one side.
3. now add your sealant, sponge some really sudsy water onto the bead & rim, and have your list of cuss words ready.
4. add air with your compressor and see if it can get the one unseated bead to seat.
mechBgon is offline
Old 02-01-12, 06:32 AM
ed
ed's Avatar
Bikes: Hecklah
Wrap the circumference with a rope. Cinch it down as you put air in with the compressor.
ed is offline
Old 02-01-12, 12:29 PM
Lindenwood
Aah, you guys are brilliant! I will try those tricks next time I get a chance!
Thanks, guys!
Old 02-01-12, 01:12 PM
Papa Wheelie
Papa Wheelie's Avatar
Bikes: Specialized Stumpjumper EVO R; Salsa Spearfish 2; Cannondale Six13
Here is another trick that I have used when a tire is being difficult.
After you get the sealant into the tire, and both beads inside the dish of the rim, start with the stem down, and use your thumbs to push the middle of the tire down as your use your fingers to pull both sides of tire out towards the rim. Rotate the tire about 4 inches, repeat. Rotate, repeat. Continue that process until your stem has made one entire revolution. My tires have all aired up after trying this process of pulling the bead towards the rim.
Good luck!
Papa Wheelie is offline
Old 02-01-12, 01:31 PM
ed
ed's Avatar
Bikes: Hecklah
Aaaahhhh, the advantages of tubeless
ed is offline
Old 02-01-12, 06:35 PM
pablosnazzy
pablosnazzy's Avatar
Bikes: rocky mountain SLAYER!!!! trek, voodoo, surly, spot, bianchi, ibis
and this is why it won't work. if you really really want tubeless setup, then spend the money and do it right.
i'm sorry, it's a weird philisophical point for me...
<rant>
i want something, but i can't afford it, i don't want to spend the money it takes to get what i want, i don't want to do what i'm supposed to for it, but i want it so i deserve it so give it to me anyway and make it work.
you don't *need* tubeless, people have been cycling for many many years with tubes. people want it, but they don't want to go about it the right way, then they complain tubeless sucks, or they come into a bike shop and make a huge mess spraying stans and soapy water everywhere cause they just want to "borrow your air compressor while i put my tube on" and we are all watching them knowing it aint gonna work.
</rant>
pablosnazzy is offline
Old 02-01-12, 07:00 PM
electrik
electrik's Avatar
You do not want get bukkaked at 40psi by your Stans! lol
electrik is offline
Old 02-01-12, 07:47 PM
mechBgon
mechBgon's Avatar
<rant>
</rant>
From what I've heard, tubeless has a super application in thorn-infested areas.
mechBgon is offline
Old 02-01-12, 07:58 PM
corvuscorvax
Gone.
So let me get this straight. On BF, you can say "bukkake" without getting censored, but not "**** sapiens".
Really.
corvuscorvax is offline
Old 02-01-12, 08:58 PM
pablosnazzy
HAHAHAHAHAH...excellent
Old 02-01-12, 08:59 PM
pablosnazzy
it does, i have tubeless on my main bike, and wow it saved me from many many flats...but you don't need it
Old 02-02-12, 12:25 AM
Lindenwood
Pablo:
I don't need to mountain bike, but I wanted to. However, while a $2000 bike is better in many ways than my $600 bike, I also didn't need to spend the money on one when a $600 bike would at least get me started enjoying the benefits of MTBing without a huge initial investment, especially knowing there are hundreds of others satisfied with this level of bike performance.
If the analogy wasn't clear, I understand the benefits of a purpose-built tubeless setup. But not everyone wants to spend hundreds of dollars for perfection, just like not everyone wants to spend $2000 on a bike just because some guy on the internet might look down on me. Further, there are at least hundreds of riders out there who are completely happy with their various "ghetto" conversions, or I wouldn't have attempted in the first place (just like I wouldn't buy a $600 bike if everyone said they were junk). Finally, do intend to buy a second set of wheels down the road so I can have two mounted sets of tires, but I didn't want to spend hundreds now on a set of wheels and tires just to try something different, especially when, as you yourself acknowledge, I don't even need it.
But, thanks to everyone else for the suggestions. I probably won't get to them until this weekend, but I'll post my results.
Old 02-02-12, 10:27 AM
Daspydyr
Daspydyr's Avatar
Any one tried this method?
https://www.youtube.com/watch?v=60lFj9SZ8JA
Daspydyr is offline
Old 02-02-12, 10:38 AM
corvuscorvax
Gone.
Pablo:
OK, that's completely cool. But then why are you so bent on having tubeless tires of all things, when tubes work perfectly fine?
FWIW, my bike cost a hell of a lot more than $2K, and I run tubes.
Old 02-02-12, 10:57 AM
Lindenwood
tubes work perfectly fine?.
Two flats inside a week is far from perfection for me . Not sure what killed the second one, but I pulled a. 5" thorn out of the first flat a few days ago though, Heh.
Of course, I am looking at only like 7% failure rate as far as flats per ride since I got the bike, but as I start taking longer trips I would like the confidence of a tubeless setup.
Old 02-02-12, 12:24 PM
corvuscorvax
Gone.
All-righty then. Good luck with the sense of confidence you'll get from the Stans.
(Hint: pablosnazzy is giving you very good advice.)
Old 02-02-12, 01:49 PM
Lindenwood
This would be the first review I've seen stating or even implying that tubeless setup with a good sealer is just as prone to ride-stopping flats as a standard tubed setup. So are you saying I wouldn't get any fewer flats by going tubeless?
