Brompton Extended seat post - any downside?
Bikes: Trek 820, Cannondale F500 with Trekking bars and road tires, Bianchi Alfana, Panasonic PCI "Les Maillots", Cannondale M1000 Tandem, Schwinn Johnny, Trek Lime, 1964 Armstrong, 1962 Raleigh Gazelle, 1964 AMF Hercules, Brooklyn Cruiser Driggs
I put a deposit on a new Brompton today (M6R). It is spec'd almost exactly like I wanted but one thing it has that I didn't think I needed is an extended seat post. My inseam is 30" and I've ridden a few others for several miles which I think were standards size without issue.
I am not as concerned about weight, I'm a heavy rider and will rarely have to carry it.
Is there a larger fold? Will I have a tougher time packing it? I do plan on air travel with it. I thought I read that it's thicker. Might that be an advantage?
Bikes: Brompton M6R, Novara Buzz
I have a Brompton with a telescopic seat post. Besides the minor extra weight and cost I can't think of any downsides to it.
One advantage is that it makes the seat very easy to remove.
Thanks for the response. This isn't the telescopic post, it's just a longer post. I have heard some advantages for the telescopic post. Like taking the seat out easily to pack without having to remove the seat from the post. The could be a plus for packing but I don't know how much trouble this longer extended post will be. I thought I should know prior to buying the bike. Maybe I could change it out.
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
I put a deposit on a new Brompton today (M6R). It is spec'd almost exactly like I wanted but one thing it has that I didn't think I needed is an extended seat post. My inseam is 30" and I've ridden a few others for several miles which I think were standards size without issue. ... Is there a larger fold? Will I have a tougher time packing it? I do plan on air travel with it. I thought I read that it's thicker. Might that be an advantage?
B and W International
We currently recommend that our customers opt for the telescopic seat post if they intend to use this B&W case. With the normal seatpost, the bike is a tight fit. With the telescopic seatpost you can easily remove the saddle making it much easier to fit the Brompton into this case. Your Brompton dealer should be able to swap the extended seatpost for a telescopic seatpost (at a additional charge, of course ).
-HANK RYAN-
Norman, Oklahoma USA
Thanks. Thats the advice i was looking for. I am going to ask for the telescopic post. I want as little frustration as possible.
I got an extended Post for my Mk2 3T. kept it when I Got the M3L , just wont slide down to be fully lowered ,
due to the extra inch or so.
tube wall thickness is said to be + 30% over the Standard [ IDK what the lower portion of the telescoping post is ]
Put a few extra KG on the saddle , Myself, I doubled up the Frame QR with a second one gripping the seat post itself,
to cure slipping down as I Ride. .
