Lemond Poprad owners?
Hey,
I have a chance to buy an old canti poprad frameset (size 57). Could be a fun bike, but I'm having a hard time getting a handle on the fit. Toptube looks a bit longer and headtube way shorter than I'm used to on my road bikes. Anyone have experience with these bikes? Thanks!
Bikes: Masi Giramondo, Trek 830 monstercross build, Raleigh Gran Sport, Lemond Tourmalet
Quoted: 121 Post(s)
Liked 19 Times
I have a Lemond Tourmalet, which is a different machine, but the fit may still be applicable. Mine is a 57, and I fit a 60 in other makes. Lengthwise it's good, but I flipped the stem up to get a better stack height. Not a big deal though since road bikes all put your hands pretty low. I think the Lemond fit might be overstated...just make sure the frame is tall enough, you have to judge that. Bigger issue is I'm guessing tire width probably maxes out at 35 - Lemond stopped mfr before the gravel/adventure/allroad thing hit so it's probably strictly UCI cross spec.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 758 Post(s)
Liked 809 Times
What size road frame(s) do you ride? How do they fit(on the large side, small side, or just right?)
Quoted: 1872 Post(s)
Liked 692 Times
Hey,
2019 Salsa Warbird
2019 Salsa Warbird
I have an '05. They do fit a little big, and when I bought it I was riding a 56cm road bike but have bought a 55cm Poprad. I'm 5'11", and I have shorter legs and a longer torso, so the long top tube is perfect for me. Another curious thing about the bike is that, as you noticed, the head tube is short. As a result, the fork is actually a little longer than standard. I discovered this when I went to upgrade the fork to a carbon one. Any standard cyclocross fork would have lowered the front of the bike a bit, so I ended up going with a Bontrager carbon fork with the correct length.
Anyway, it's a great bike and I love it, although I'm also casually in the hunt for a CX bike with discs (targeting the All-City Macho King at the moment).
Quoted: 6934 Post(s)
Liked 10,940 Times
I've got an '03 Tourmalet in size 57, don't know if it has the same geometry as the Poprad. But the TT is 57.5cm. With the stock 115mm stem, it fits about like my other bikes which are 58cm TTs and 110m stems.
My Tourmalet does have a short headtube, but a long steerer tube on the fork. So that is workable for me.
So, no, I don't think Lemonds are larger than the stated size, if you look at the TT length.
I will also say this: is the Poprad made of Reynolds 853 steel? Because if it is, that's gonna be a sweet frame.
I usually ride a 59, but fit is tricky. Got long legs and a short torso, so road bikes that are the right height for me often feel long (hence my concern about the Poprad's headtube and toptube). However, I've never owned a cross bike, so I wonder if the slacker angles will make up for the longer geo.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I usually just go for the cockpit length (top tube + stem). Everything else is fairly adjustable. Cross bikes tend to have low head tubes as they are designed for racing, although you can raise the stem and angle it if you need to.
Cross bikes don't have slack geometry, unless you are comparing them to road (track or crit bike). Even so, its not slack like Gravel , hybrid, or mtb bikes. They are meant to turn aggressively at relatively low speeds.
Quoted: 758 Post(s)
Liked 809 Times
From what you've said, I think if a Lemond will fit you, it'll be a 57cm. The following link has the spec-catalogs for the Lemond bikes in the Poprad era. The catalogs will have the Poprad as well as the road bike frame geometries. If you know your existing bike's geometry you should be able to get a reasonable idea of relative fit.
Trek, Fisher, Klein, Lemond bike catalogs, bicycle brochures
Quoted: 425 Post(s)
Liked 452 Times
I used to focus on tt length but now consider ht length equally important. Frames with modern geometry tend to have taller ht lengths which effectively reduce reach. OP's concern is warranted but if the fork has a long enough steerer it will allow for some adjustment there.
I have roughly 10 road bikes, including a Poprad. If I was forced into the choice of taking a single bike into the afterlife (hell by definition), I would take the Poprad over my other newer, far more expensive bikes.
Great do-it-all bike. Reasonably light (in the rim brake version), huge tire clearance and great ride.
The only measurement that really matters on a bike is the top tube c-c. Find the top tube that fits you.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have an 05 poprad as well. I normally ride a square 56cm road bike with a 100mm stem and the Poprad (with a 90mm stem) fits perfectly. The fit is different than most CX bike that I've ridden. I sit in the frame more than on the frame, which is something that I prefer.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
