NBD - Canyon Endurace
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 925 Times
Canyon Endurace CF SL 8 Di2 (what a mouthful) in Stealth Grey, size Medium
Only about 10 miles on it so I can't really speak to many of the features and ride quality other than it fits great and so far I'm very happy. Because of "supply chain" issues the Continental 5000 tires ended up be substituted with Goodyear F1 Tubeless (30mm) and at 80psi they feel like I'm riding in sand. I will be replacing them with some 25mm clinchers asap. One nice surprise was they threw in a 4iii NDS power meter. I like that it also acts as a Cadence Sensor so that I don't have to attach my Garmin sensor to the crank arm
I'm still trying to wrap my head around all this new technology. This is my first time with Di2 and Hydraulic brakes. Having 12 speeds is also pretty weird. There's just a lot to absorb.
The whole buying experience was great. I live near one of their warehouses and had it in 2 days. A few questions popped up during the assembly process but Canyon's online chat cleared those up right away.
Quoted: 1819 Post(s)
Liked 1,696 Times
I would say that you should first set these tires up the way they are supposed to be set up if you haven't done it already. I ride 700 x 28 tubeless on another bike and they are an improvement over the 700 x 25's I was using before(same make and model tire)
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
Those Goodyears got panned when they were released because of their relatively high rolling resistance... that said, that was compared to other top end tires, so they shouldn't be horrible in the grand scheme of things. I'd check whether or not tubes are in there and I'd also lower the pressure pretty significantly, unless you're a big dude.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
That is a nice surprise. It's stock on the SL8 "aero" model, maybe someone in the US assembly factory didn't notice they pulled the wrong sku ?
Liked 925 Times
I was reading a thread in another forum and someone mentioned the same thing happening to them. Not the exact power meter but it was substantial. Others talked about Canyon throwing free t-shirts and other swag into the bike boxes before they shipped.
Likes For TakingMyTime:
Liked 925 Times
Question: Did you set the tires up as tubeless or do you still have inner tubes? Riding road tubeless tires with inner tubes isn't the most efficient setup which could account for your "riding in sand" impression. When I received my Grizl in February the wheels were already taped and the tires were tubeless ready but supplied with inner tubes installed. I already had a couple of tubeless valves which I installed and made the conversion, took me about 20 minutes altogether.
Liked 1,696 Times
I will be removing the front wheel later today to deal with a squealing brake issue and will do a complete inspection. I'm leaning towards them having tubes installed since the valve stems do not seem to have any special locking rings that might also assist in leak prevention. The tires are only rated to 80psi and I've been running them around 75-78psi. On my previous bike I was riding 23mm clinchers bumped up to 90-100 depending on the day.. I weigh approximately 195.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
Kudos on the Eundurace! I got one two years ago, the CF SL 7, with 105. It's fast, comfy, handles well - everything you want in a bike, really.
Likes For genejockey:
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
Congrats! I love mine.
The power meter is a really nice add-on.
I'm betting they ran out of regular cranksets along with the GP5000s.
Likes For BTinNYC:
Liked 1,696 Times
Tubeless is simply part of the learning curve on newer bikes and is easily reversed. I have been riding tubeless on the road for the last 12 years and it is just as easy to deal with as inner tubes.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Liked 9,456 Times
Likes For WhyFi:
Quoted: 1163 Post(s)
Liked 442 Times
But if you don't try your current tires full tubeless, then your impression of the ride quality of "like riding in sand" is going to be skewed. I have very inexpensive DT Swiss R460 rims set up tubeless on my 2x10 titanium road bike and the full tubeless implementation that I am running is much different than if there were tubes in there. Cornering, shock absorbtion, road feel are all excellent. You owe it to yourself to try it out. If you need assist to set them up tubelesss the first time, your local bike shop can help you. Once set up full tubeless, you may also safely lower the pressure to see what that does for you. Since you say the Pirelli's are 30mm, I would say that the pressures you are currently running them at would most certainly be quite a bit lower when set up full tubeless. Advantages to tubeless road tires extends beyond just flat prevention.
climber has-been
Liked 3,567 Times
Liked 925 Times
That is valid and point well taken. Logically I don't see any reason not to pull the tubes, put in new valves and some sealant. The investment would be minimal.
Advocatus Diaboli
Liked 1,533 Times
Congrats on the new bike. I don't know how or why this thread though became a tubeless crusade. Just ride and figure it out. Goodyear tires... get anything else and you'll probably be golden.
Liked 1,696 Times
Not sure about the tires you have, but many road tubeless tires will hold air without sealant. At least mine do and the tires on my gravel bike also hold air without sealant. When I converted my Grizl to tubeless, I simply deflated the tires, and then removed the inner tube, installed the valves and pumped them back up. I left the bike overnight and the tires were still fully inflated the next day. I did inject sealant through the valves because I was going to ride on unpaved roads and trails, but sealant wasn't needed so that the tires hold air. Canyon has a video on their website showing how to convert. If you just want to try your tires tubeless to see the difference all you might need is a couple of valves
Advocatus Diaboli
Liked 1,533 Times
SL8 Di2 FROZEN YELLOW
Liked 9,456 Times
Took another look today at Canyon's site.. is this a new color they're now offering in your bike model? Called "Frozen Yellow", I don't remember seeing this before.
Likes For WhyFi:
Liked 925 Times
I believe it's been out for some time. I did see one in this color in their showroom and the color looks much better in person than in pictures.
Advocatus Diaboli
Liked 1,533 Times
Liked 11,912 Times
You gotta admit, though, it sounds better than the actual color, which is beige.
