Non-shifting 32-tooth chainring for Shimano STX crankset--Any suggestions?
Howdy,
I'm doing a little project on an old mountain bike, and want to install a 32-tooth chain ring on the crank, nothing else. (And I'll be using four or five sprockets on the rear cassette.)
Of course, I don't want the chain to be inclined to slide off as I'm shifting the rear gears, so I'm wondering if anyone has a recommendation for such a chainring. I've read that most compatible chainrings (like Shimano's something-glide style) are machined to allow the chain to shift easily off the chain ring when changing gears.
So, to distill: What's a good non-shifting 32-tooth chainring compatible with the five-bold pattern of my Shimano STX crankset?
Thanks for your help.
Jowdy
Jowdy
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Do you know what the bolt circle diameter (BCD) of the crank is, specifically for the middle chainring? See here: https://sheldonbrown.com/harris/chainrings.html
I'm guessing 110mm. In that case, the smallest chainring that will work is 33T, which is rare (https://www.sheldonbrown.com/harris/chainrings/110.html). Should be able to easily find a single-speed 34T chainring, such as https://www.universalcycles.com/shopp...s.php?id=16021 Just make sure it is for 3/32" NOT 1/8" chain.
If the middle and outer chainring positions are 110 BCD, the inner chainring spot will likely take 74mm BCD, which can take a 32T. You'd probably want to get a longer bottom bracket so that the new chainline of the inner chainring can be similar to the original chainlline of the middle chainring.
If you do have a 110mm BCD crank, I suggest just using a 34T and adjusting the size of your cogs to accommodate the slightly higher gearing.
There were some older STX cranks that had unique chainrings. Without a model number or photo, it is difficult to give definitive advice.
MARGINALS
Bikes: 09 Tarmac Pro SL / Sunday BMX /
A non-ramped chainring like the one Salsa makes should work out for you. As far as I know STX cranks used a 94/58 bolt pattern.
https://www.universalcycles.com/shopp...7&category=649
All,
Big thanks for the feedback; this all points me in good directions.
And, Turkey, thanks for the brief breakdown of complexities to consider. It helps as I slowly gain an applicable vocabulary for this stuff.
j
j
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
I also recall STX or STX-RC having an odd pattern... maybe the right BCD for some standard size, but standard rings still didn't fit very well.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
If you go with a Surly, be sure to add a bash guard. If you're not going to add a bash guard, Surly isn't a good choice, look for a beefy aluminum chainring.
