Trainer Tires ???
Bikes: 73 Raleigh Supercourse, 99 Specialized Stumpjumer, 08 LeMond Tourmalet
Trainer Tires ???
I just got a used Kurt Kinetic and even if I crank down the resistance unit to the max (5 turns) and lower my tire pressure I can still make it slip. Running a 23mm Conti GP4000S tire. I am certainly no Chris Hoy ... so I am wondering if a dedicated trainer tire on an extra wheel would help or is it just a waste of money.
thanks.
thanks.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
My KK came with a Vittoria trainer tire. I get about the same amount of slipping between it and a GP4000s. Both are better than the scrub Krylions that I've tried using.
While I can make it slip if I want it to, I don't actually think it affects my work outs too much because I don't tend to do a lot of sharp jumps indoors. But it is annoying and I don't remember it being a problem with my old Cycleops Fluid.
I have a Continental trainer tire. Slips, sure. But I have it 'cause the trainer chews through normal tires.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
thanks.
thanks.
If it's setup correctly, you shouldn't be getting slipping, certainly not to the point that the slipping would be a problem.
I'd check how you've got the bike in the trainer. Also what air pressure in the tire?
You could get lost and die.
You could hit a tree and die.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
I've run pressures at 100 and 110 (my usual road pressure). 23mm GP4KS on a Hed C2 rim. I've cranked down to as much as 4 full turns and I can make it slip from a stop or from a spin if I shift and stand. It doesn't slip during steady state work just at the first kick of any sprint. Maybe this is normal? The responses above seem to indicate a specialized trainer tire isn't worth it. I can buy a cheap tire and put on an extra rear wheel I have.
pan y agua
Liked 728 Times
^ 1) from a stop there's no reason to put out the sort of torque to make it spin, just get things turning in an easy gear while you warm up.
2) jumping out of the saddle, you can make it slip a bit initially, but I've never found it to slip emough to matter. Also, I just don't find the trainer conducive to sprint intervals, so I don't so them on the trainer.
Quoted: 2952 Post(s)
Liked 3,106 Times
I agree. It doesn't seem worth the expense to get a single purpose tire. Do you have any worn down but not completely clapped out tires? I'd just use one of those.
2) jumping out of the saddle, you can make it slip a bit initially, but I've never found it to slip enough to matter. Also, I just don't find the trainer conducive to sprint intervals, so I don't so them on the trainer.
2) My high intensity intervals start around the worst part of winter here. Believe me I'd rather work on the road ;-)
Thanks for the tips!
Bikes: Pinarello FPQuattro, Giant XTC 29er
Quoted: 50 Post(s)
Trainers are simply not great at emulating the 22% incline sensation of low 50s cadence yet 350-400 watts of effort. To get 350+ watts or more from KK or fluid trainers, you have to both max gear AND keep cadence high. With high enough cadence, you can get 800+ watts of resistance.
Fortunately, there's probably no value about specifically training with specifically uberlow cadence. You can get all the fitness benefits as well increase your speed on those 22% inclines simply by doing intervals on the trainer at speed, even if the cadence ends up being higher than it would be on taht 22% climb.
Don't decrease the tire pressure. Increase it to make it stop slipping. It's a smooth surface; surface area of the contact patch doesn't change the friction against the roller. Tire pressure puts a limit on the pressure on the tire patch; if you want more friction on the tire patch, you want more force against the tire patch, in which case you want more air pressure in the tire.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Bikes: 2012 Litespeed C1R, 2009 Jamis Xenith SL, 2010 Jamis Xenith T, 2012 Ridley X-Fire
I prefer a dedicated trainer tire for two primary reasons:
- I hate to swap the tires from regular road use to trainer use - so I use a dedicated trainer wheel/tire combo
- Trainer tire is way better (for the trainer) that any regular tire: less heat buildup, no tread separation, less noise, super sticky to the drum, lasts way longer than regular tire
Klickety-Klackety
Bikes: Ones with 2 wheels...
This is what I do as well. Got the same ratio cassette but just a cheap version, tossed it onto a take off rear wheel I got from my wife's Ruby (upgraded her wheels for her) and a trainer tire. Works great and it's just a rear wheel swap...
Wut
Wut
Quoted: 1186 Post(s)
Liked 289 Times
I just use old tires I have laying around. I've never worn out a used tire on the trainer and can't imagine riding enough indoors to worry about buying specialized tires. Since Oct I've done more trainer rides than any other season and I'm still only up to 20 hrs. Usually 1 to 1 1/2 hrs at a time is about all I can handle.
I use 3 turns and 110(ish)psi. I usually just do tempo intervals from 260-280W so I don't encounter much slippage.
CAT4
Bikes: 2009 Cervélo S1, 2009 Felt F75, 2010 Cannondale Synapse Carbon 5, 2011 Cannondale CAADx, 2011 Specialized Transition Elite
I've had the same crappy wire bead Hutchinson that I've used for 2 seasons prior. It shows almost no signs of wear after initially depositing some rubber on the mag roller. It'll last through this winter without question. Slippage only happens with abrupt starts. I'll just use another old tire when that one gives up the ghost (it's a bit dry-rotted, but if it lets go on the trainer, I don't care).
Cardiac Case
Bikes: Trek, Cannondale, Litespeed, Lynskey
Like others, I do not use my good tires on the trainer. I save my worn tires. When its indoor trainer season, I mount them back on for use on the trainer. Otherwise, I would just buy the cheapest tire I can get. Typically no more than $10 and is found in the LBS' bargain bin.
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
up until this year I've always used an old tire for a trainer tire with no problems whatsoever. This year I got a dedicated conti trainer tire at my lbs just cuz it was on sale. Not much difference that I can tell.
