View Poll Results: What size tires are you using for your road bike?
700x23
117
54.17%
700x25
84
38.89%
other
15
6.94%
Voters: 216. You may not vote on this poll
Are you riding 700x23 or 700x25's tires?
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
I have always gone 700x23 road tires. My tricomps have reached their life limit and served me well, but I was offered a deal that I couldn't pass on with a set of specialized turbo tires. Last set of specialized mondo pro tires I had were 23's but seemed a little wider than previous sets I had. All my buddies at my LBS are trying to convince me to get the 25's because it will be a better/smoother ride, corner better, better rolling resistance....etc. Being that I'm a bit of a weight weenie, Its difficult for me to get past the additional 45g I will be adding by going with the 25's instead of the 23's. Trust me, I know this has been talked about in past and 45g is not a huge deal to a lot of people but when you have spent hundred of dollars to drop weight, its difficult to buy something that will add weight. I wanted to see what the majority of people here are riding.
Would love the following info:
-what bike you ride
-what wheels you have
-what tubes you are using
-Preference between the 2 tire sizes or pros/cons?
-what bike you ride
well hello there
Quoted: 503 Post(s)
Liked 336 Times
23s. But when they wear out, I've got a set of 25s waiting to try.
L-I-V-I-N
Bit of a weight weenie is a bit of an understatement. 23's for you.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
King Hoternot
Quoted: 127 Post(s)
I'm NOTHING compared to some of the guys over at weightweenies.com! Those guys shave the clear coat on their frames, saddle, bars...etc. Drill holes in the seatpost, levers, cages, crank arms... Its Crazy to see what some REAL weight weenies will do!
My buddy at my LBS just told me to TRY them and if I hate them, he will swap them out for the 23's. I guess I have nothing to lose.
The improved rolling resistance more than compensates for weight according to a variety of articles I have read. So choosing lower weight means you are sacrificing performance, which makes no sense since point of lowering weight is improved performance. To get best of both worlds, get lightest 25mm tires available.
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
If you are a light weight then you won't feel a difference. That's my experience. The quality of the tires will matter more.
Underwhelming
Bikes: Lynskey R330 Ti, Dean El Vado Ti, Trek 4300
Lynskey R330 and Dean El Vado Ti bikes
Mercury alloys and Campy Eurus 2-way fit
No tubes-tubeless on both
I've used 25's before and much prefer a wider wheel like the Mercury with a 23 tire. Cornering is incredible, rr is supposed to be lower. 25's felt disgustingly fat around a corner and the handling wasn't as good. Tires were Gatorskins--another tire might have felt different.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12782 Post(s)
Liked 7,696 Times
Mostly 26. Panaracer Stradius Sports don't come in 25s.
L-I-V-I-N
I think this is key. I'm on 25's because I'm a clyde and need to run 23's at a really high pressure.
Thanks for taking the WW comment in stride.
King Hoternot
Quoted: 127 Post(s)
Quoted: 2952 Post(s)
Liked 3,106 Times
I actually have 23mm on the front and 25mm on the back.
King Hoternot
Quoted: 127 Post(s)
Quoted: 86 Post(s)
BTW, i'm running 20's at 80 PSI.
King Hoternot
Quoted: 127 Post(s)
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Can't believe you're handicapping yourself with a beach cruiser like that. 80PSI? Really?
Do you really not understand that the more POUNDS per square inch that you put into your tires, the more weight you're having to carry up the hill???
Bikes: Rixe track bicycle, 1986 Schwinn Paramount, 1988 Schwinn Tempo, 1985 Schwinn Tempo, 1972 Raleigh SuperCourse
I ride 23's, rougher ride, but fast on good roads!
25 at psi 90 & 100. Way more comfortable, and less fatigue on 100-160 km rides. Supposedly faster but I can't tell the difference.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
The decision is personal and depends on many factors.
I would say if you are heavy (>180ish) and/or riding on rough roads, you should certainly go for 25.
Personally, I am light (135-140) and roads are reasonable, so I ride 23's.
I agree you have nothing to lose so try them...
