opinions on chain catcher?
Bikes: 2012 Cervelo R3 Team
I wanted to ask people out there if they have any opinions one way or another on the usefulness of a chain catcher?
I picked up my bike from the LBS yesterday after having them re-install my power meter magnet for the 3rd time. The mechanic recommended that I install a chain catcher, b/c he thought that the reason the magnet was falling off was b/c my chain was dropping. In fact, my chain was dropping b/c the magnet was falling off.
In any case, it got me wondering if I would like to get one just in case. After I thought about it more, I realized that if my chain dropped, the likelihood that the magnet would break away again would just increase. So I became intrigued a bit.
In normal circumstances, I don't worry too much about dropped chains. It rarely happens to me, and when it does, it's not a big problem to fix (since I don't race; at least not yet).
Do you guys find that it is helpful? Does it work really well? Or is it just $50 down the drain?
Thanks.
Thanks.
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
Chains bounce off sometimes no matter how good your drive train is setup. Adding a chain catcher just eliminates the hassle. $50 your shop is ripping you off.I have a dog fang $20 on e-bay on one bike and K-edge $18 PBK on another.
Liked 6 Times
I totally recommend a chain catcher for anyone who has a carbon frame. I once saw the damage a dropped chain can do on a carbon frame on a fellow's new frame, it was not pretty. And to think a $9 (that is what I paid on PBK for my Dog Fang) contraption could have prevented all that grief.
So, get yourself a chain catcher, and do it fast!
Maud Magnet
Bikes: 2012 Specialized Allez Comp, 2001 Kona Stuff
I'm kinda on the fence about them...
If your FD is set up correctly, then dropping a chain on the inside should be rare.
Of course, the chain can bounce off on a downshift in the right conditions even if your FD is perfect - and I've had my share of these.
But for me, it's never been a problem to get the chain back on while riding & I've never gotten any frame scratches from it.
That said, I'm not knocking them at all. It just seems like an extra hassle to me... one more thing to adjust.
Liked 6 Times
And the guy I saw drop his FD and got his frame chewed up resulted from hitting a nasty, unseen pothole.
Have you seen that almost all pro bikes now come with a chain catcher? There is a reason, and it's not FD maladjustment by incompetent or drunk mechanics.
Bikes: Look 585
Quoted: 25 Post(s)
When I started seeing chain catchers on Tdf bikes I knew it was time for me to get one. If these professional mechanics think they're a good idea, I do as well.
Maud Magnet
The operative word being "rare". What about the single drop that chews up the BB area of a carbon frame? All it takes is one unfortunate drop, which can result from a myriad of causes. I don't think Andy Schleck's FD was not adjusted properly when he dropped his chain in the Tour. User error, maybe, but definitely not a maladjusted FD.
Bikes: Pinarello FPQuattro, Giant XTC 29er
I use a chain catcher but it didn't prevent an incident of "chain suck" where my dropped chain came around and was wedged between the inner chainwheel and the frame below and behind the BB. Chewed up the paint pretty well - although at least it didn't do any structure damage to the frame. I don't know how I could have prevented this (& its only happened once) but I know that the catcher has saved my chain from dropping on the inside at the top a few times. It also makes it easier to re-mount the chain; which is often done on the move by good riders (ie pros) and perhaps thats the reason they have one. It means they don't have to stop.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
essential.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
The Recumbent Quant
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I have the K-edge catcher, got it on eBay for $20, works as advertised the two times I had a drop and its worth every cent for the peace of mind. I still check things on the FD/RD adjustment, though, just because I'm paranoid don't mean they aren't out to get me.
Bill
Bill
Semper Fi, USMC, 1975-1977
Clearly ridiculous to describe it as essential when nearly everyone has managed just fine without them for ever and ever.
According to reports, Andy Schleck was using one when he dropped his chain and lost the famous 39 seconds to Contador, so they aren't foolproof.
I've never used one, and never felt the lack. I rarely drop the chain, and if I do I can almost always get it back on while in motion, simply by shifting back onto the big ring.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
I have dropped the chain on all three bikes i have owned. on 1, it would have destroyed the frame if it had been carbon. People may well say it is user error, but that is a moot point. Errors are made, even if it is avoidable.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i bet you are an anti helmet retro grouch.
Maud Magnet
I call BS.
You may have nicked it or scratched it, but you definitely did not bend it. Not unless you stomped on it out of frustration afterwards... and that doesn't count.
Liked 6 Times
What the eff kind of crazy stunt did you do to BEND the chainstay of a steel bike from a chain drop???
I call BS.
I call BS.
Maud Magnet
Why on earth would you question someone's direct experience? For your info, chainstays are sometimes deliberately thinned out to elicit certain ride characteristics. And the chain is the hardest part of a bike, as it is mostly steel (harder alloys combos), whereas frame materials on a steel bike are " softer alloys" of some kind. So, it is very possible to bend a chainstay on certain steel bikes from a chain drop.
I don't have any idea what kind of dainty rainbow & unicorn steel bikes you're talking about, but in the real world, simple physics do not support your assertion.
*MAYBE* this could happen on an outside drop where the chain gets wedged between the crank arm & chainring and the rider continues to mash on it with all his weight & might.
Otherwise the chain would not have enough inertia, force or leverage to bend something.
But we're not talking about outside drops, only inside, because that's the only kind of drop a catcher can prevent, yes?
The Recumbent Quant
If this had been a thread about helmets, or lights, or gun control, I could see how it could deteriorate this quickly. About chain catchers? Did not see this one coming...
Maud Magnet
That & I'm bored at the moment waiting for files to process.
Not every bike can fit a dog fang. If you tube flares out toward the bottom bracket and you have a clamp-on FD, then you need something like the clamp-on K-Edge, which is around $50.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
You can get knock off K Edge chain catchers on ebay for less than 10 bucks. I use one. It's fine.
https://www.ebay.com/itm/140814143264
