Yet a new bike category? Salsa’s new Warroad (no bird required)
#76
I calculate. My calculations also don't match up with the manufacturers', so when I compare, I compare between my calculated values.
#77
Quoted: 1872 Post(s)
Liked 692 Times
There's nothing inherently more comfortable about a gravel bike frame versus a road bike or endurance road bike frame. In reality most gravel bikes are significantly less comfortable than a comparable road bike because they feature larger diameter tubing formed for strength/durability which adds significant stiffness as does the oversized headtubes/steerers.
A road bike that fits 32s is much more comfortable than a gravel bike on 32s. Hell the gravel bike I won is as stiff and possibly stiffer than the track bike I own.
2019 Salsa Warbird
2019 Salsa Warbird
#79
Sunshine
Quoted: 10959 Post(s)
Liked 7,487 Times
There's no theory, just experience, measurements and math. Headtubes and steerers are almost 60% greater in diameter, rectangular downtubes/chaninstays and toptubes that are almost the exact same measurement between mtbs and gravel bikes. If you're bored one day, take a measuring tape or caliper to REI or your LBS or whatever and measure the tubes. The wall thickness for almost all aluminum tubing used in bikes is the same - the area of the tube is what matters and where stiffness/compliance comes from. My gravel bike has a 52mmx48mm downtube. This is enormous and is slightly larger than my hardtail from the same year. It's ridiculous.
Bigger tires and lower pressures aren't magic, especially once speed increases. There's no way to make a production bike with an oversized 44mm+ steerer, headtube and fork have the same compliance as a similar bike with regular 1 1/8" components. A big driver for road plus was to get overbuilt rigid mountain bikes posing as gravel bikes back to a comfort level of the previous generation of converted cross bikes/early gravel bikes. When a frame is built stiff enough to act as a pivot point for a suspension fork but is actually a road bike you need 47mm+ tires to get anything approaching acceptable ride quality. And even then it's only in the same area and often not as compliant or comfortable.
There's an old saw about if you're really so into frame/fork compliance ride your bike without tires and see how it matters. The reality is, ride your bike with 23mm tires at 5% sag and see how much it matters. It matters a bunch and the current generation of gravel bikes are a big step backward in terms of ride quality, regardless of whatever marketing and brand iconography we've all internalized.
Keep in mind a big part of the brief for frame/fork design of production bikes is passing european/ISO fatigue testing. It's part of the reason standard tubing went away during the steel years, why 1 1/8" steerers happened and why oversized headtubes are appearing on any bike meant for non-paved riding.
I am 235# and my OS steel frame gravel bike hasnt ever felt noodly. Even though it hasnt felt noodly, would a 44mm head tube and OOS tubing feel better? Or would it be too stiff? Thats something that would be frame and bike specific and would only be answered with extensive riding, which isnt realistic without buying the frame/bike.
My current steel frame design(still subject to change many more times, im sure) is a mix of OS and OOS tubing to hopefully make a slightly stiffer frame than what I have, which still being far smoother than what I would otherwise get if buying something already made.
An OS seat tube, head tube, and top tube matched with an OOS downtube. That downtube would hopefully help offset the oval chainstays i will use since oval bent stay will naturally flex laterally more than the round stays that are crimped on my current bike.
The only settle is that I will use a carbon fork with straight steerer so thatll limit me to a Woundup or Ritchey...and the Woundup has a longer steerer which i will need, so i guess ill go with that. At the same time, to get a different carbon fork would require a 44mm head tube and giant tapered steerer which is all probably more stiffness than I need.
I ride gravel solo and a 15mph average on a 30+ mile route is a really good day. I wont set records and wont ever snap cranks due to Herculean power. Pretty sure a front end and bottom bracket can eventually be too stiff for my benefit.
Anyways, interesting points you bring up. I didnt realize there is someone else who sees the tubing diameters of some frames right now and questions the claims of comfort.
#80
Quoted: 427 Post(s)
Liked 339 Times
First of all, a gravel bike will have a stack measurement thay sets up the handlebars up to 2 inches higher than a road bike for a more comfortable riding position on long day rides that are more common on gravel bikes. (more comfortable)
Second, Gravel bike frames are built to be stiff laterally, but have much more vertical compliance to absorb road vibration. (Take a back view if a Warbird for example) (more comfortable)
Third, Gravel bikes can accomodate tires up to 40 or more MM, while few road bikes can fit even 32mm (more comfortable)
Fourth, gravel bikes ALL are built for Disc brakes, and until recently almost all road bikes came with caliper brakes (Maybe not more comfortable, but certainly easier on your hands on a long decent)
Fifth, gravel bikes normally have a longer wheelbase and slacker head angle compared to a road bike. This adds to comfort and creates stability, where road bikes have shorter wheelbases and steerer head angles for quicker maneuverability. (more comfortable)
And sixth, gravel bike riding is cool and growing fast while road bikes are a dying category!
#81
Quoted: 427 Post(s)
Liked 339 Times
Yeah, I've probably tried a gravel bike or two in the past. They were nice and I liked them, but not snappy/fast enough to replace my Tarmac; and not versatile enough to replace my Cutthroat. I guess I could dig up an excuse to fit an expensive purpose built modern gravel bike in between the two (nothing wrong with more bikes!), but honestly not sure if I would get enough miles on it to justify.
#82
Non omnino gravis
Isn't road geometry with bigger tires basically just a CX bike? My Swiss Cross is essentially a Road Logic with a higher BB, longer chainstays, 10mm shorter reach, and a 1.5ş more slack headtube. But the Cross will just fit a 38 in back, while the Road Logic will just fit a 30. I've absolutely zero complaints about the comfort of my Ritchey. It is unquestionably my "all roads" bike.
I just looked at the geometry for the Warroad in my size-- no thanks. That's way more relaxed and upright than what I like. That's long before I get to the bonkers pricetag. It's priced at least $1,500 over what it's worth.
#83
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
As opposed to "gravel bike" which has never really meant anything at any point. Whether OS tubing or not.
#84
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
That is funny, I've found gravel bikes to be relatively compliant. But stiff carbon bikes of 10 years ago, or Aluminum bikes of 20 years ago may not be the best benchmark. ;-) Back in the day stiffness was where it was at.
These days bikes are more likely to be " "Laterally stiff and vertically compliant." To me, this means a stiff bottom bracket area that applies my power efficiently, but the fork, bars, seat stays, seat tube, seat stem can all be compliant, making the bike comfortable on the road.
Just with my bikes, my track and gravel bike have similar stiffness where it counts, and similar acceleration, but my track bike is a nightmare on anything less than velodrome smooth. I was shocked doing 20mph on some horrid washboard on my gravel bike with 32mm tires - and I was just cruising along without realizing how bad it was. None of my older bikes can do that.
I have some old bikes that really twist under power. I can see the crank arms and the bottom bracket twist, and if my tire is too big it will rub against the frame.
Disk brakes don't seem to be a friend of ride quality though. Those older forks with the J bend had suspension built into them. These days with straight blade forks, necessitated by the torque of disk brakes, require other creative solutions to get a little front end compliance in them.
#85
Non omnino gravis
I run a Surly Straggler steel disc brake fork, and it's great. My old KHS had a straight-blade CF fork with an aluminum steerer, and it was the very manifestation of the word rigid.
Seeing the fork flex under heavy braking is a little disconcerting the first few times. Sure does ride nice, though.
#86
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
#notAllGravelBikes
#87
Liked 692 Times
I heard somewhere Tom Ritchey doesn't believe in oversized/tapered head tubes for gravel bikes because it makes them too stiff.
#notAllGravelBikes
#notAllGravelBikes
2019 Salsa Warbird
2019 Salsa Warbird
#88
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#90
Sunshine
Liked 7,487 Times
I'm of the same mindset. I had read all the whitepapers and forum posts (written by road industry personas) about how frame/fork was a minor part of compliance compared to other parts of the bike and the tires. Then I started riding my gravel bike on mtb trails and paying attention to how much worse it rode than my cross bike. Double OS steerer/fork with MTB frame tubes - "gravel bike." Then I saw the Ritchey video which made me cut up some of my broken frames to measure the wall thickness, then I started measuring and weighing the new gravel bikes and frames when they came into the shop and now here I am arguing on the internet about it.
Funny too, I rode a early 90s Cannondale R900 aluminum frame/fork that had a reputation for being extremely stiff and uncomfortable but a great racing bike. That frame has thinner tubing, smaller diameter tubes and is almost a full pound lighter than most gravel frames on the market right now. It's kind of a "duh" thing to say but it illustrates how the acceptable compliance window has shifted significantly now that we've all been marketed heavier stiffer frames and forks but with much wider tires than 25 years ago.
Oh- and what was the 2OS frame you refer to?
#92
Liked 2,011 Times
#93
Sunshine
Liked 7,487 Times
#94
Liked 692 Times
edit: I'm dumb, but I'm agreeing with you. I don't know if that was clear. It's been a long day.
2019 Salsa Warbird
2019 Salsa Warbird
