Merida Speeder Max Tire Clearance
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Does anyone have any idea of the maximum tire width of a Merida Speeder? They come with 700x28C tires, but I'm wondering if you could fit slightly wider tires, say 700x35C, with fenders.
https://www.merida-bikes.com/en/bike...9/root/fitness
I had a close look at a Speeder that was parked next to my bike today. It had fenders and, I'm guessing, 32mm tires. By the looks of it 35mm shouldn't be a problem. But this bike was an older model, so not sure if the tire clearance has stayed the same in current version. However, seeing that the lower spec current models also have 32mm tires, 35mm should still be fine.
Likes For subgrade:
