Where EXACTLY do I lube the Derailleur????
can someone put up a pic of a derailleur with an arrow pointing EXACTLY where I put lube? I would need it for both the front and back derailleurs.
Plus where else exactly do I lube? Do I need to lube the cassette? Where exactly on the cables do I lube as well. Brake pivots points to right?
Forgive my noobiness.
Pivot joints on brakes, with cables I put a small amount down the cable housing. Lube from your chain should suffiecently lube the cassette.
B-b-b-b-b-b-bicicle Rider
Bikes: 1997, stumpjumper S-works hardtail, Medici, Giant Perigee(track dropouts and fixed gear), Columbia twosome, schwinn twinn, '67 raleigh 5 speed internal hub, Old triumph 3 speed, old BSA 3-speed, schwinn Racer 2spd kickback, Broken raysport criteriu
Liked 5 Times
Lube the pivot points on the brakes, and down cable housings (shift and brake) as already said. on the deraileur (it has parallel arms for moving it in and out so there are 4 pivot points there, and the pulleys also rotate forwards and back and spin so lube those pivots, and I prefer taking the deraileur apart and greasing the pulley axels, but if you're afraid to do that, then squirt some lube in there if they feel stiff. You will not need to lube the casette as it actually doesn't have moving parts, it just sits on a spinning cassette freewheel, you can squirt some penetrating light oil into that if it's feeling gritty and sluggish, if it's not, leave it. too much lube just collects dust and sand so go light, and wipe off anything that drips down the outside parts you can reach.
I found some pics on the net, and labeled them as to where to lube, so see attatched pics please.
I hope this helps
Quoted: 2026 Post(s)
Liked 1,095 Times
