Trek 7.2 FX new fork + drop handlerbars upgrade
My Trek 7.2 FX commuter has been badly vandalized. Someone probably kicked/jumped on the front wheel. Besides replacing a tacoed wheel and bent fork I wanted to take this opportunity to upgrade to drop handle bars.
I found a Nitto 105 locally for cheap and am looking for suggestions on fork, stem, brake levers, bar end shifters, etc.
I found really good info here
https://www.bikeforums.net/archive/in.../t-578606.html
I'm planning to buy the following
Tektro RL520 levers
https://www.tektro.com/02products/11rl.php
Shimano 8-speed bar end shifters
https://www.amazon.com/Shimano-SL-BS6.../dp/B000F5EFOC
Nashbar fork
https://www.nashbar.com/bikes/Product..._10000__200456
I'll work on the bike at a bike co-op so access to tools won't be an issue. I appreciate any suggestions you may have.
Tektro RL520 levers
Nashbar fork
Likes to Ride Far
Try to find out what the rake on your current fork is and see whether this is similar to the replacement. The axle drop-out to crown race distance should also be similar to make sure that the bike's handling won't change.
I'm using a pair of those levers, and can vow that they work and feel very good.
Thanks. I have learned so much about brake types/levers compatibility in the past few days.
I emailed Trek and thankfully got the fork specs from them; went with the Forte Axis Carbon fork which doesn't have v-brake mounts. Can I use the Tektro RL520 levers with caliper brakes? What are my options here?
Quoted: 1074 Post(s)
Liked 295 Times
Can - yes. Recommended - no. Wire pull is different, so brake feel is different. Some are happy with it though.
Pretty much any "regular" drop bar brake lever meant for canti-caliper brakes.
The Tektro R200 levers work with caliper brakes. Nice levers for the money.
SurlyLaika
Bicycle Mechanics
5
03-26-13 09:50 AM
hajitosan
Bicycle Mechanics
16
09-26-12 03:15 AM
