Breadcrumbs at the bottom of the page as well?
Bikes: 2013 Novara Strada
Can breadcrumbs be added to the bottom of the page in addition to (or, less ideally, instead of) at the top of the page? Since most people read posts from the top of the page to the bottom, it makes sense to have the breadcrumbs at the bottom of the page, just below the last post. Having to scroll to the top of the page to go back to the forum I was in takes energy I could be using cycling. d-: Any chance it could be added to the bottom of the page?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Someone else asked this very same question not too long ago...https://www.bikeforums.net/showthread...bottom-of-page
Community guidelines
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
If you look on the right hand side of the screen in the space below the latest post in a thread and above the text box, you will see two buttons- "Forum Suggestions & User Assistance" and "Top".
The first one tells you which forum you are in and if you click it, gives you a drop down menu that will allow you to scroll and navigate to any area that you have permission to use by clicking on the appropriate name, by-passing the need to go back to the main index page.
The second one that says "Top" does exactly that- takes you back to the top of the page you are on and then you can navigate from there.
Thanks for the suggestion, no1mad. It's a helpful alternative. I still think breadcrumbs at the bottom would be better. (; I do appreciate the assistance, though!
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
There's also the PageUp button
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
Yep, but that is because we are using desktops and laptops. Those using tablets and smartphones typically don't have a Page Up/Home key.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
True but tablets and smartphones can usually do a throw scroll and be at the top of the page, and don't get me wrong I'm totally pro breadcrumbs at the bottom just throwing out stuff they can do for now.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
We're reviewing this now, by the way. ANytime you make changes to a database, you have to plan for what will potentially break.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Sophomoric Member
Fantastic! They used to have this years ago, and I have missed it ever since.
"Think Outside the Cage"
Sophomoric Member
For iPad, just touch the black bar at the top of the screen and you will be whisked to the top o' the page.
