Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 01-27-14, 04:56 AM
  #376
Velocirapture
Velocirapture's Avatar
Bikes: S-1 :-D
Quoted: 17 Post(s)
I always use the master link - I take the chain off when boxing up my bike, and some gear changes need different chain lengths.
All the ones i've used come with a spring clip to make sure there is no popping off, though, like the picture below
A chain that is separated often with a chainbreaker would make me nervous.
File Type: jpg
Velocirapture is offline
Old 01-27-14, 11:19 AM
  #377
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Originally Posted by MarkWW
I think I've seen two fail. I'm pretty sure one was user error and the other was the garbage two-piece master link that comes on a SRAM PC1. It's connected by flexing the chain and popping on an outer plate. The problem is if you flex the chain too much, it bends the link and the outer plate doesn't stay in place.
Like this:
I'm 99% sure that it was user error.
I've never seen one fail.
Chains have a greater chance of failing when you remove and reinsert pins. Modern chains are not designed for such. They are designed to be used with the master links (like above).
carleton is offline
Old 01-27-14, 12:12 PM
  #378
Brian Ratliff
Brian Ratliff's Avatar
Bikes: Three road bikes. Two track bikes.
Quoted: 47 Post(s)
Liked 4 Times in 4 Posts
Originally Posted by Baby Puke
I've never had that happen nor have I heard of it happening until now. Though I pretty much only use the crew and nut type. Anybody else?
I've never had the clip type fail on me, but I've had a "screw and nut" type fail when I didn't tighten the nut tight enough and the screw worked its way out. I always put screw and nut type chains on nut-out now, so I can easy inspect and see if the nut is still in place and the screw tight.
I've also had a chain outright break on me when I was using a 1/8" chain on a 3/32" freewheel and a bad chainline. I believe the chain was trying to ride up on the tops of the 3/32" freewheel teeth causing a lot of pressure on the sideplate, eventually separating one. For this reason, I'll never again use a 1/8" chain on a 3/32" cog.
I agree with Velocirapture that using chains where a chainbreak has been used to remove a single pin too many times makes me nervous. The ends of the pins are a press fit; not as bad as road chains, but enough that every time you remove a pin it very slightly enlarges the hole.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Old 01-27-14, 10:00 PM
  #379
sbs z31
Ok thanks guys and I think my next chain I'm planning to get I'll use the masterlink. Another question, do you guys think I'll be fine with a Shimano UN55 bottom braclet or should I go with a higher end bottom bracket?
sbs z31 is offline
Old 01-27-14, 10:34 PM
  #380
MarkWW
Bikes: A little of each
Quoted: 23 Post(s)
Liked 4 Times in 2 Posts
The UN55 is fine. I think I raced my first two seasons on a un55. Problem Solvers does make an aluminum version of the non drive side plastic cup if yours cracks or anything, but that's not usually an issue.
MarkWW is offline
Old 01-27-14, 10:49 PM
  #381
sbs z31
Thanks and Shimano UN55 bottom bracket it is then.
sbs z31 is offline
Old 01-28-14, 02:16 AM
  #382
mxs
Bikes: Bianchi Pista
I really like the screw-type link on my Izumi. Are the side plates specially made for these or could I hypothetically pop the pin out of a 710sl and use a spare screw from an Izumi?
mxs is offline
Old 01-28-14, 03:28 AM
  #383
carleton
Elitist
carleton's Avatar
If you notice on the Izumi V chain, the pin threads into both the opposite plate and the nut (that acts as a locking nut). The K710 doesn't have a threaded plate to accept the screw and I wouldn't depend on just the nut.
So, no, hypothetically you can't do it.
carleton is offline
Old 01-28-14, 05:07 PM
  #384
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
Here a small, random question: Zipp 900 disc, do these ****ing bearings ever loosen up and smooth out? After a year of ownership, still decidedly crunchewy. Don't tell me to go ceramic.
Baby Puke is offline
Old 01-28-14, 05:22 PM
  #385
carleton
Elitist
carleton's Avatar
Is it new?
I have a zipp 900 disc and I have had to have the bearings replaced once already. They are an odd size, so I had to get the shop to order them directly from Zipp. They are sort of thin (using smaller ball bearings). Thinner than normal bearings from sealed hubs.
Maybe you can get a warranty replacement set?
carleton is offline
Old 01-28-14, 05:45 PM
  #386
Baby Puke
Quoted: 365 Post(s)
Originally Posted by carleton
Is it new?
So I guess you're saying this is not normal. I've had it for a year, used only for racing, so it's rolled half a dozen times or so.
Old 01-28-14, 06:52 PM
  #387
Soil_Sampler
A little North of Hell
Quoted: 71 Post(s)
kmc 710
kmc pin
Soil_Sampler is offline
Old 01-28-14, 07:48 PM
  #388
Slavic
The worst.
Those interested may find this upcoming BMX chain of interest:
It uses an allen key based master link that works via threaded pin, comes with both half links and full 1/2" links, and may help out people who worry about breaking their chain all the time for different gear ratios.
Edit: It's called the Key chain, and it's made by Odyssey.
File Type: jpg
Slavic is offline
Old 01-28-14, 08:04 PM
  #389
carleton
Elitist
carleton's Avatar
Here's an interview with the product manufacturer: https://www.odysseybmx.com/dailyword/...hris-cotsonas/
It's hard to tell if it's on the market yet. It was announced over a year ago.
carleton is offline
Old 01-28-14, 08:24 PM
  #390
MarkWW
Quoted: 23 Post(s)
They'll sound a little noisy just by nature of the disc construction, but you shouldn't feel anything abnormal while spinning it in your hand.
MarkWW is offline
Old 01-28-14, 08:56 PM
  #391
slindell
Zipp wheels seem to run a bit rough in my experience. To find the right bearings check on the Zipp site. https://www.zipp.com/support/identify/hub_timeline.php The bearings are all available in steel or ceramic at various places and not too bad to replace unless you get into the freehub, but you don't need that on the track.
slindell is offline
Old 01-28-14, 09:04 PM
  #392
Slavic
The worst.
Not on the market yet, but should be in production by the time the 2014 season rolls round.
Slavic is offline
Old 01-29-14, 12:18 AM
  #393
Baby Puke
Quoted: 365 Post(s)
It ain't noisy, the bearings just feel like crap. Anybody have a buttery feeling 900? Did you have to do anything to get it that way?
Old 01-29-14, 08:58 AM
  #394
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
small question- does *Anyone* have a link to the last day of the Berlin 6?
Seems that some serious business went down.
Hida Yanra is offline
Old 01-29-14, 09:01 AM
  #395
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
aw man, really?
what'd you hear?
queerpunk is offline
Old 01-29-14, 09:08 AM
  #396
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
Originally Posted by queerpunk
aw man, really?
what'd you hear?
Here's a Six-day dot com news recap, or some of the racers were tweeting about it last night.
I'm just counting the numbers on my fingers here, but it seems like a pretty serious throw down.
Old 01-29-14, 11:18 AM
  #397
Impreza_aL
Impreza_aL's Avatar
Bikes: yellow tricycle di2 grip shifters
i've owned both the non dimpled and dimpled 900, they both spun well. from what i remember there is a slight bearing preload when installing the track axle. have you tried giving it a 1/8 turn to loosen it?
i actually preferred the non dimpled version because it was heavier that thing carried speed very well.
Impreza_aL is offline
Old 01-29-14, 03:26 PM
  #398
Baby Puke
Quoted: 365 Post(s)
I don't know about other versions, but this wheel is a 2012 model and there is no preload adjustment on the axle. Its either tight or its not.
Old 01-29-14, 05:12 PM
  #399
Quinn8it
Quinn8it's Avatar
Bikes: Bianchi Pista, Bianchi Vigorelli
Ffwd ftw
Quinn8it is offline
Old 01-29-14, 05:24 PM
  #400
carleton
Elitist
carleton's Avatar
Originally Posted by Quinn8it
Ffwd ftw
Are the stickers removable on those yet?
Zack K. here in Portland is sponsored by them. I asked him to send that feedback to them. They would be waaaaay more popular if the stickers were removable like they are on Zipp and Mavic wheelsets (their direct competition that happens to be out-selling them).
The new Shimano track set is also nice...but the stickers are not removable.
Logo overkill is a pet peeve of mine
On a related note:
It's a rolling alphabet. It's like camouflage...seriously.
Can someone photoshop that bike and black-out the logos? I don't have PS on my work computer.
carleton is offline
