Front wheel problems.
I ride fulcrum 1 racing wheels and hubs and have had good luck with them over the years. Today though I noticed the front wheel not turning well, obvious resistance. The tire and wheel is free from brake pads, frame and brake calipers. No obvious contact points. When removed the wheel spins fine, It is only when placed in fork and the lever closed. If my spare wheel, same type and tire, is used to replace it there is no problem.. Any ideas?
Quoted: 6556 Post(s)
Liked 58 Times
Is there a preload adjustment on the bearing cartridges? Maybe too loose and has caused bearing damage. Turns fine when bearing preload is loose, but when tightened in the dropouts with the skewer, the bad bearings are resisting rotation. ?? Maybe.
Note to self, no more deep puddles.
