rear hub/freewheel 2012 CADD 8 105
Does this unit have free bearing or is a baring set. Does this unit required lube or maintenance?
CADD8 105 2012
CADD8 105 2012
I have NEVER regretted going on a ride;
I have often regretted not going when I could have!
I am grateful for the headwind that challenged me today!
I am grateful for the tailwind that helped me go fast!
Clydesdales and Athenas Strava Club
https://www.strava.com/clubs/clydesda...bikeforums-net
Quoted: 336 Post(s)
Liked 309 Times
In general, the axle bearings are cup and cone, and the freehub is replaceable, but not serviceable.
If you get the part number from the hub, you can find exploded drawings on Shimano's website.
Quoted: 839 Post(s)
Liked 1,061 Times
Shimano cassette bodies are fairly easy to flush and lube. Doing this every 7K-12k miles will help it last for a very long time. Tutorial here.
Likes For Crankycrank:
THANNKS! my rear was disassembled, cleaned, bearing repacked. CrankyCrank, you rock, twice you have shared a video I needed to see. Thanks
Quoted: 839 Post(s)
Liked 1,061 Times
Glad to help. YouTube is great for maintenance and repair videos. Much easier to see it done than have it explained IMO especially when I'm trying to explain it. I also hate throwing things away when some occasional maintenance or repair can make it last for many more miles. Also Shimano cassette bodies like a heavy oil such as the Phil's in the video or heavy automotive gear oil or if you happen to use "Chain L" chain lube I find it to be one of the best. Too light of an oil and it will seep through the seals in med-hot weather and grease is too heavy and can cause the pawls to stick especially in colder weather.
