Tire pressure loss due to heavy rider?
Quoted: 14 Post(s)
Newbie here. I weigh around 235 pounds and ride a Trek Dual Sport 3 with Bontrager GR2 700C X 40MM tubeless tires. If I set my pressure at 50 psi after every ride (average ride is between 20 and 30 miles) it will go down to 40 psi. It doesn't matter if I am riding gravel or road - the exact thing happens (I usually set it lower for gravel but the times I did try 50 it went down to 40). When I asked the guy at the bike shop he told me I should not be at 50 and I should be at 40 and because of my weight it will lose air. Is this normal?
I think your bike guy is blowing smoke up you no where.
Likes For Mulberry20:
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
40 PSI is rather low for your weight. It’s probably fine for the front but for the rear, you really should be running around 60 to 70 PSI. Any lower and you risk bottoming out on bumps and damaging the rim.
Stuart Black
Stuart Black
Pressures seeking equalization over time, will always be with you NB Tubeless is not air tight ..
I have a few wheels with the thick wall heavy duty thorn resistant inner-tubes OTOH, they hold air for a long time..
Quoted: 14 Post(s)
Does it go down after each ride or overnight? If it is overnight, that’s perhaps a bit much but not outside of the expected pressure loss due to diffusion. Tires lose some pressure over time because the rubber is only mostly sealed. Nothing about your weight should have an impact that would cause a change in tire pressure.
Quoted: 14 Post(s)
Down the line I will consider that but since I paid for the conversion labor (and the tubeless tires) when I purchased the bike last month I want to give these a chance for a while.
Likes For teeebone:
Pennylane Splitter
Bikes: Yes
Quoted: 1796 Post(s)
Liked 1,439 Times
As mentioned above, change over to tubes and use tires with higher pressure ratings; I'm not sure if there are any 700x40 with higher pressure ratings. I'm only slightly lighter than you and I run 700x35s tires with tubes at 80 psi. I loose about 5-10 psi per week (which I consider normal). Plenty of good 35s tires on the market that'll handle gravel and graded dirt.
Quoted: 6963 Post(s)
Liked 10,961 Times
OP: I believe that when a shop sets up tubeless tires, they don't necessarily have time to do all of the things that help create a good tight seal. I suggest that you read up a bit on the 'net and do these things yourself at home. It's not a big deal, and it will optimize your setup. Try steps 9-14 at this page.
PS: Make sure the sealant level is adequate. On initial install, some of it seals up the sidewalls and other gaps, so you may need to add a bit.
Likes For Koyote:
Expired Member
Quoted: 3665 Post(s)
Liked 5,417 Times
Why not check immediately after a ride? How much is lost overnight is less of a concern. You probably should not exceed the max pressure on the sidewall, especially with tubeless. Remember, you'll often lose a few psi while removing and attaching the pump.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Keep in mind you loose air and pressure when you pop the pressure gage on and off.
I'm a 270# Clydesdale and have no pressure loss issues once my 40mm tubeless tires have been properly sealed. In fact, they do better than my old road bike with skinny tires and tubes.
Expired Member
Liked 5,417 Times
Now pump them back up to 50 and check again after an hour or however long you were on your ride. That will tell you if the loss has anything to do with riding.
Likes For shelbyfv:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
How are you checking pressures? It's almost impossible for me to check pressures without the process causing the tire to leak down some.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Low pressure also increases the risk of pinch flats. That's the tube getting squeezed between the rim and edge of a pothole or other abrupt edge.
Liked 4,217 Times
teeebone has tubeless tires but many people don’t understand that tubeless doesn’t prevent the rim from bottoming out. Pinch flats are a symptom of a problem. The problem is still there with tubeless but there aren’t any symptoms. Bottoming out a rim can result in damage to the rim. Personally, I’d rather deal with fixing 25¢ pinch flat vs a $100 bent rim.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 10,961 Times
Likes For Koyote:
Liked 10,961 Times
by the way, I only top off the air pressure in my tubeless tires every several days, about like my tubed tires.
I put tubes in my tires , On my last loaded tour soloing I topped off the PSI every couple days,
because I ran thorn resistant tubes & I could feel a bit more rolling resistance with a bit less pressure
10 month tour, no punctures..
Some people actually think they're supposed to lower their tire pressure when hauling more weight, maybe they think the weight adds pressure or something.
Add *more* air pressure to compensate for more weight.. something has to push back when more weight is coming down to keep the tires in the right shape to perform.
Just don't exceed the max and you're good.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
OP, I wouldn't run tubes, especially on gravel. But as others have mentioned, it sounds like they didn't do a very good job taping the rims, or maybe didn't put enough sealant in. I've retaped two wheels that a shop did, and they're holding air better now, altho tubeless tires will always lose air, just the nature of the beast. But tubeless on gravel is def the way to go.
Likes For Rides4Beer:
Liked 10,961 Times
You probably would've gotten no punctures (at least none that didn't immediately seal up), and a smoother ride, with a tubeless setup. But you're free to do what you wish.
load it up with tire sealant?
.. ride was plenty smooth with 40 poinds of camping gear and 3 season clothing. in my 4 panniers..
& atop the rear rack..
Quoted: 14 Post(s)
Just by attaching the floor pump (Bontrager dual charger pump). Interestingly enough my wife has the exact same tubeless tire (bough the bikes and had them converted the same time) and she is not heavy and all our tires after inflated to 50 go down a little right after the ride but within 24 hours go down to 40. They seem to hold at 40 but won't hold at 50 (even without riding). Guess fat me isn't causing this but could a bad seal be stopping it from staying at 50 but holding steady at 40?
