It’s crank measuring day
Quoted: 1561 Post(s)
Liked 1,734 Times
I bought a 155mm Origin8 crankset for my wife’s bike. I gather the Origin8 crank is a BMX crank. I needed to check if the chain ring spacing is good for double chain rings. So I measured the thickness of the chainring mounting tangs for various Shimano cranks for comparison:
600 FC6400: 3.4mm
RX100 FC A550: 3.5mm
RSX FC A410: 3.8mm
105 FC5700: 3.5mm
Origin8 crankset: 3.7mm
So it seems like 3.4-3.5mm is typical, but for some screwed up reasons the RSX crank is 3.8mm. Why Shimano why? Anyways the Origin8 crank looks to be in the ballpark.
600 FC6400: 3.4mm
RSX FC A410: 3.8mm
105 FC5700: 3.5mm
Quoted: 1944 Post(s)
Liked 2,164 Times
I’m not going to look up all the cranks, but you do realize that Shimano, and other manufacturers, adjusted the chainring spacing to accommodate narrower chains used for a higher number of cassettes cogs.
The reason is that you can’t run a 10 speed chain on a crank designed for a 6 or 7 speed chain. There is a good chance it will float between the chainrings when you shift between rings.
John
John
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Also, I am mostly in the small ring, so don't shift the front much.
It's not perfect, but quite workable. I wouldn't use it on a race bike.
Really Old Senior Member
John
John
I had concerns, but I didn't notice a single problem with my 9 speed chain.
It was apparent that 165mm made a wonderful difference vs 170mm, that I immediately ordered a new, cheap triple. So, it was probably less than a week that I ran the cotters. It was a friction shifter, so I have no idea on the indexing.
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
What does this mean for your swap?
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
Liked 1,734 Times
You would think so , but the 5700 (10 speed) has the same spacing as the 6400 (which started out as a 6 or 7 speed group) and RX100 (8 speed), while the RSX (7 speed) is an outlier by itself.
Likes For icemilkcoffee:
