No jam nuts on old wheel
I have acquired an old single speed Katakura Porta Silk folding bicycle. It's from the 60's I believe.
Anyway, I'm in the process of cleaning it up and getting it into running order and as I've been taking it apart, I noticed that the front wheel hub does not have jam nuts to lock the axle cones down.
At first, I was thinking these nuts were somehow lost over the years, but now I'm wondering if that used to be a thing?
Could it be that on some older wheels you lock the cones down by just using the outer lock nuts - the same nuts that are used to hold the wheel to the fork?
It seems like if that's true, then every time you take the front wheel off, you would have to fine tune the cone adjustment.
I've never seen that before, but then I have limited experience in these things.
Thanks for any insight that can be provided.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
The dropped
Liked 1,014 Times
https://www.bikeforums.net/classic-v...e-locknut.html
The rest of us call them locknuts. I learned that Raleigh manufactured front hubs used a shoulder on the axle to lock the drive side cone in place, again without locknuts. The drive-side cone will tighten with normal hub rotation if it's allowed to rotate. If the cones and cups aren't wrecked already, set them up as suggested in the thread (leave a little play) and really tighten the axle nuts after getting them finger tight without causing the axle to spin while doing so.
Likes For Unca_Sam:
