"Play" in wheel bearings
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
I recently read in RBA that it is a good idea to check your wheel bearings for "play." I had not really ever done that before.
I checked, and I am able to move the wheel side-to-side about 1mm (maybe slightly less) measured at the rim.
Is this normal "play" or do I really need to tighten the hub's bearings?!?
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,950 Times
Depends on the bearing type. A sealed bearing wheel may have some play in it. but a cone and race type should not have any play.
Liked 8,919 Times
he said member
Bikes: yes please
Liked 1,950 Times
Liked 8,919 Times
Quoted: 1606 Post(s)
Liked 2,570 Times
Has a sealed bearing, do you still have the tool that came with it?
Same idea https://www.tech-mavic.com/tech-mavic...mFrontAxle.pdf
Liked 6 Times
There should be a slight play that the QRelease should take out when clamped.
Post #2: There should also be a tiny play in a cone and race hub that the QR should eliminate when clamped.
