9 speed cassette on 10 speed shimano hub?
Old 01-12-21, 10:24 PM
goldfinch
goldfinch's Avatar
Bikes: Norco Search, Terry Classic, Serotta Classique, Trek Cali carbon hardtail, 1969 Schwinn Collegiate, Giant Cadex
Quoted: 23 Post(s)
Liked 5 Times in 4 Posts
I have a nice set of handbuilt wheels with a shimano 10 speed cassette. The hub might also fit 11 speed cassettes, I can't remember for sure. Anyway, I would like to move these wheels to the bike I am riding the most, which has a nine speed cassette and I am happy with the nine speeds. So, can I put the nine speed cassette on the 10/11 speed hub? And in reverse, put the 10 speed cassette on the nine speed hub? Spacers needed?
goldfinch is offline
Old 01-12-21, 10:38 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Until 11 speed, 8, 9 & 10 speed FH bodies were the same length.
You ADDED a 1.8mm spacer if using a 10 speed cassette because the "stack" is actually a bit shorter than 8 or 9.
Longer 11 speed bodies need additional spacing if using fewer cogs.
A bit of Googling on How many on how many will return lots of results.
Bill Kapaun is offline
Old 01-12-21, 10:48 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
some Shimano 10 sp hubs have taller splines and will not work with a 9 sp cassette.
icemilkcoffee is offline
Old 01-15-21, 10:47 AM
goldfinch
goldfinch's Avatar
Quoted: 23 Post(s)
So, I will try moving cassettes. It is an 11 speed DT Swiss hub that I want to fit the nine speed cassette on. It does have a spacer for the 10 speed cassette. Will search for what I might need for spacers. The first hit says a 1.85 spacer.
I take it that the 10 speed cassette will fit on the nine speed shimano (bontrager) hub.
