Fatties For Foldies
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times
I love it.
Are they 'bouncy?'
What is the PSI?
Wow, I never thought of it in mm. My Kenda Kwest 1.5 100psi tires are 38mm.
And the usual 1.75's are 44mm and they are 75psi.
Thank you for putting this out there.
Are they 'bouncy?'
What is the PSI?
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I have big ben plus on my recumbent trike. Slightly wider than big apples. they roll well. Can't go much bigger if I use my fenders but at 2.15 I am very comfortable.
Quoted: 802 Post(s)
Liked 249 Times
If you are looking for very fast puncture resistant 2"/50mm wide 20"/ETRTO406 tires, there are also the excellent Continental Contact Urban that exists in 50x406.
For higher puncture resistance, there are the new Continental eContact Plus that exists in 50x406, 55x406 and even 62x406.
Whippersnapper
My Bike Friday has 20 inch wheels, so I've been able to use 2.4 inch BMX tires on it. I currently have some fetching pink Salt Plus Sting tires, and I have some knobby Kenda Booster Pros for more serious unpaved rides. If you drop the pressure enough, the Kendas are like velcro. The Salts are heavier and not tubeless compatible, but they are half the price. I have wide rims, and the Kendas are a true 2.4 inches/61mm wide. The Salts are a couple MM narrower. I'll try to get some pictures soon.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The coolest looking 20 inch tires I’ve seen lately are the multicolor camouflage Vans
honestly there are such a ton of dirt jump and street BMX tires that I don’t think there should be any lack for folders
Genesis 49:16-17
Genesis 49:16-17
Quoted: 802 Post(s)
Liked 249 Times
Wide tires for small wheels folding bikes (and actually for almost all bikes) are beneficial.
Riese & Müller understood that long time ago and designed the Birdy frame to accept wide tires.
Brompton didn't and stayed with 35x349 high pressure tires while Kinetics and Eerder Metaal are making custom fork and rear triangles allowing wide tires.
And these wide tires are not only good for comfort and versatility they can also provide lower rolling resistance if couple with a relatively high pressure like for the Greenspeed Scorcher and TruBlu 40x349 and 40x406 race tires.
Vee Crown Gem 57-305/16x2.25 with knobs shaved almost off, stretched out to 67mm on a 50mm wide rim from the trailer range. That is my best match on that bike for occasional offroad, unpaved paths. The frame clears also 16x3.0, but the tire i tried was way too heavy and stiff, Chaoyang Sparrow. The bike is meant for 406 wheels and in this setup the BB height is 27cm.
Likes For splithub:
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
The Origami Swift comes standard with 50-406 tires, and there is room to go bigger.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Likes For Pinigis:
Likes For Pinigis:
Uh Ron, you clearly are peddling your wares, the presence of retail packaging and partially built bikes is proof. What's your shop called Ron ?
Likes For Bleu:
Schwinnasaur
On the Xootr Swift, the rear dropout is horizontal. I had to add Surly Monkey Nuts to be able to fit 50 mm tires. With fenders, it won't go above that. I like that used a more standard drop out.
Quoted: 463 Post(s)
Liked 567 Times
You must be impressed easily if you think there's been any thunder from anyone in this thread.The thunder of an outdated cult relic brought back to modern times, you mean? You wish. Yeah, the Frankenstein Origami neo-Swift is really shaking the industry...🙄 Just look at the number of views on its vids on the Origami YT channel. Paul can't keep enough in stock. They are flying off the shelves. Xi Jinping has decreed round-the-clock production in the factories of China. It's a veritable tsunami. That's why Pinigis shamelessly opts to sadly peddle it here, that's right. 😂
Instead you are still sore, licking your wounds from that time that I pointed out the absurd grappling hook of a long-cage derailer that you installed on your folder a while back. This, despite the fact that you yourself admitted to the folly of it. 🤡
That same time when you threw a tantrum due to my pointing out what you yourself feared and admitted, you declared that you would put me on ignore (wow, that really sent shivers of regret and remorse down my spine 😂. But evidently that was a vacuous, risible fib, a real tantrum cuz...well...you have not ignored me and here you are again commenting on my threads and posts again. 🤡🤡 Between your own reneging and the repeated flounces of the JoeRem!/Bleu sockpuppet, I am getting a series case of whiplash here.My suggestion to you that you put me on Ignore. For real, this time. No empty threats, posturing or lies.
Quoted: 463 Post(s)
Liked 567 Times
Ah, yes, of course. That's why you talked about the make and model of a bicycle but failed to talk about the make and model of the particular tire. Right, you were talking about tires. Yan had you pegged quite accurately.
Quoted: 452 Post(s)
Liked 405 Times
The tires on the Origami Swift tires are Arisun XLR8 20x1.95
Paul Pinigis
Paul Pinigis
Quoted: 560 Post(s)
Liked 651 Times
You're not a gate keeper for BF
You may NOT tell us when to ignore
You may NOT tell us when to unsubscribe from a thread
You may NOT tell us when and how to post... PERIOD
So throw yet another temper tantrum, show us your true colors.
oh, and my bike is still better than any of yours.
Likes For CrimsonEclipse:
On both of my Hooligans(not folders, though) I installed MTB 20" wheels to accommodate wider tires. These are 20x2.35 tires on the bikes
Likes For shrooms:
Uh moderator...
Huh, I really don't have anything against you or the stuff you sell. I don't have any affiliation with Origami or Brompton or any brand. I don't know Paul Pinigis. So after I stated the obvious, that you are a dealer or distributor of folding bikes, you went to name calling (sockpuppet) and hostility. Odd , very odd. Oh, I don't know JoeRemi either, nor what anything he may have said has anything to do with this thread. I DID chime in to defend Pinigis from an unfair attack on his post, because your assertion that he is doing something wrong by highlighting features of his products on a thread you started to plug your own products; is wrong.
Likes For Bleu:
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
This thread is going nowhere. Ron Damon started it and then deleted the opening posts. Now it doesn’t make sense. Plus insults aren’t allowed and there are plenty.
Thread closed
Thread closed
