Mounting Bottle brackets
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I am working on a Raleigh International and it does not have bottle bracket mounts on the DT nor the ST
What do you all use to mount a bottle bracket?
Or do you just carry it in another pocket, What???
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Quoted: 938 Post(s)
Liked 2,946 Times
https://velo-orange.com/collections/...tle-cage-clamp
Likes For ascherer:
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
How about these https://kingcage.com/en-ca/collectio...l-support-bolt
Likes For rgvg:
Likes For fabiofarelli:
Quoted: 3811 Post(s)
Liked 6,716 Times
Likes For nlerner:
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
DMR hinged clamps. Solid and don't have shift-around tendencies like some of the other bolt-ons do.
Velo Orange sells them, but is currently out of stock. Some of the UK vendors also sell then.
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Likes For ehcoplex:
Quoted: 3464 Post(s)
Liked 2,831 Times
‘some will clear. Some won’t.
Likes For repechage:
I very recently found out that there are saddlebags with bottle holders. Sort of like how time trial riders store their bottles. I believe Rock Bros makes one.
Likes For The_Joe:
Quoted: 761 Post(s)
Liked 1,563 Times
Likes For ehcoplex:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Quoted: 2326 Post(s)
Liked 4,997 Times
I grab some clamps from Velo Orange when I place an order as filler. They're on sale for a buck a pair right now.
I've even swapped the provided bolt with color anodized ones from Wolf Tooth to give a better match to the bike.
Steel is real...and comfy.
Likes For jamesdak:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Gugificazione!
Seriously, though, this is why I don't like vintage frames with good paint. I've used the Velo Orange clamps and a different version of the King Cage hose clamp. They work well enough, but I don't really like the look.
I think this is the VO clamp. Seeing it in a picture I think I must be pretty OCD to complain about it.
My Bikes
My Bikes
Likes For Andy_K:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I got about 8 of the Velo Orange clamps a while back for a buck per. I need to find cages they will work with now.
Quoted: 1609 Post(s)
Liked 2,216 Times
I am not sure the VO cages will work well with their bands. Some might.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
VO says on their site the current cages they offer do not work with the $1 clamps.
Quoted: 1829 Post(s)
Liked 3,378 Times
I've got the benefit of buying some T.A. bottle cages many years ago, so I can't say how easily available they are now.
On an International that has since left the stable, I used a T.A. Criterium cage on the down tube. It uses a single clamp, which makes it easier to avoid clamping onto the big Raleigh decal.
On my current '74 International with the pristine paint and decals, I've avoided clamping anything to the down tube. Instead, I just use a T.A. handlebar cage, along with a bottle in a jersey pocket.
Steve in Peoria
Steve in Peoria
Quoted: 472 Post(s)
Liked 1,028 Times
That’s what I made. I bought my Raleigh Pro in October of 2013 and did its frame up overhaul over the winter of 2013 - 2014 so I had lots of time. When it came to top tube housing clamps and bottle cage clamps, I just made them in the shop. Cut up a piece of stainless steel, bent tabs and drilled holes. SS hardware and “bob’s your uncle”. They’ve worked very well since then and look right for the era. Easy.
”way back machine”: I spent a lot of time wondering what straps to make/buy then happen to visit Browns of Beverly on Cabot St in Beverly, MA. Saw an early 70’s Raleigh 3 spd there with plain bright steel straps. “That’s what I’ll do.” Browns is long gone now. Sad.
Likes For Prowler:
Quoted: 1952 Post(s)
Liked 2,013 Times
I’m with Andy K on this. I’ve 1/2 a mind to use a Camelback 😧 when take my G.J. on a long ride.
A Rubbery Thing.
Thankfully, my L.C. Needs paint.
A Rubbery Thing.
Likes For Classtime:
señor miembro
Liked 6,488 Times
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
Pro tip: The bolts that attach the cage to the clamp are a couple of threads too long and run all the way to the bottom, they could scratch the paint underneath. File them down, use slightly shorter bolts, or add a washer like I did.
Likes For Pcampeau:
Bikes: '72 Peugeot PX-10, '09 A. Homer Hilsen, '78 Masi Gran Crit, '79 Echelon Spectra
Quoted: 104 Post(s)
Liked 163 Times
I use vintage TA alloy clamps on my Peugeot. I put little strips of thin double-sided tape on the inside of the clamp and then I put little strips of butyl tube on top of that. This keeps the clamps from scratching the paint.
Likes For BertoBerg:
