Standing while on rollers
Quoted: 38 Post(s)
Got a set of rollers for Christmas and have used them 3-4 times. I am slowly getting better at it but, realize it is going to be a while before I am comfortable on them. I tried standing up on them a few times and the bike seems to want to surge pretty good. I realize I could build the contraption I saw posted on a previous roller thread and it would help the situation. While I think the idea is great it would partially defeat the reason I got the rollers instead of a regular trainer. I specifically got rollers to help me on my bike handling skills.
My question to you'll that use rollers will I be able to do intervals out of the saddle once I get better on the rollers or, is it just not practical to do them on rollers?
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
Standing all out intervals on standard rollers are virtually impossible.
Bikes: 08 Gaint TCR Advanced, 87 Specialized Sirrus, 07 G Fisher HiFi, 05 G Fisher Tass
I converted my rollers to "motion rollers" at minimal cost by adding the wheels to the rollers instead of building a rolling platform for the rollers to sit in. I also put "bumper" wheels on too that keeps me on the roller if I drift. I can jump up on the cranks with no problems. That adds a lot to what I can do on the rollers.
Extra Medium Member
Droping the hamer since '86
Quoted: 38 Post(s)
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
I can say that even with motion rollers, intervals will be tough. I can stand easily enough and go medium-hard but it's really more for stretching than all out effort like intervals require. I love my rollers and use them more than my stationary but between resistance and stability have realized that if you're going to have to spend a lot of time indoors it's nice to have both types. If I couldn't have both I'd only do rollers though!
Quoted: 4236 Post(s)
Liked 2,949 Times
Do your rollers have a fork stand option? I wonder if that'd be useful for those times you want to do intervals vs. normal riding.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Depends on the intervals. Sprinting intervals probably not, but I have no problem doing threshold intervals, and will probably also be doing VO2Max intervals next month on the rollers. Perhaps it is foolish, but I might do some form sprints are well as we get closer to the spring. Not full-out sprints, but enough to work on form and technique. Sprinting is probably not the best for the trainer either, in the sense that your form would probably be crap if you can't rock the bike.
PS I also have resistance on my rollers, that makes a bit of a difference if one is spun out on the rollers
Haz, used skateboard wheels for the rollers. I believe they have a 1/4 " axle. I think I used roller blade wheels for the bumpers. I'll take a close up of the wheel assembly tonite and post. I did use 1/4" alluminum bar stock as brackets for the roller wheels to raise the frame up some. I have notices a slight deflection on these after about a year. I may switch to steel to stffen them up a little. Wheels still turn freely. The close up will show you what i am talking about. As Robby said, its not like standing on an open road, but it does allow you to get out the the saddle from time to time and crank for a while.
Bikes: i may have bike(s)
Quoted: 46 Post(s)
Quoted: 429 Post(s)
Liked 248 Times
yeah I have to figure out a way to get resistance on mine. Plastic drums so can't do the towel trick. Apparently I can order an old Magura unit and jerry rig it to my rollers
Also, datlas is correct. Intervals are easiest done on a trainer, for the obvious reason that you are less likely to crash. It's most convenient to leave efforts above VO2max to a trainer or road.
The "motion rollers" are a cool trick, but noobs shouldn't be deluded into thinking their only option for roller training is to buy a $600+ set of rollers or spend a lot of time wood or metal working. Riding rollers is a skill. Once you learn it, you'll be able to ride in much tighter spaces and if you can learn to stand fluidly on stationary rollers, you will never again be That Guy who shoots his bike back into someone's wheel every time he stands up.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Quoted: 25 Post(s)
incorrect, by a wide margin. But it requires a lot of practice. I would term it an advanced skill. It ranks right up there with the ability to take off a shirt while riding no-handed.
I can stand on rollers, but I can't do 1200-1400 watt jumps on them.
Quoted: 344 Post(s)
Liked 20 Times
Standing can be achieved, and also I believe it is easy with good core strength.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
Tacx Galaxia style rollers allow you get to out of the saddle, for extra resistance you might be able to add a Minoura Mag Coversion kit.
https://www.youtube.com/watch?v=SEYijdzW8yY
I can. Like I said, it takes practice.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
I can stand on my resistance rollers, but I can't sprint hard. I've been using them at least once a week for 15 years, so I don't think I'm going to get much better. Having roller bumpers would add peace of mind for sure. Still, real sprint training has to be done on the road. It's not the same either on rollers or trainer because you don't have the mass to accelerate or the momentum once you're on top of the gear. Different energy expenditure pattern and feel. Plus the rocking makes a trainer NA as has already been mentioned. That said, it is good to practice standing and going up and down on the rollers. I can do intervals up to VO2max fine on my rollers, just can't really sprint.
Quoted: 38 Post(s)
Today I tried rollers while watching TV and surprisingly it seemed I did better when I was distracted. During the commercials I was even able to do intervals at 80-85% of Heartrate Max while seated. It is tempting to put bumpers on the rollers and wheels on the roller frame since I have all the stuff to do it. However, this spring I want to start riding in a paceline and being able to "hold a line" is critical skill for doing this safely. I was told rollers is one of the best ways to learn this skill. So for now I guess it is more important thatI learn bike handling skills than hit the really hard intervals on the rollers.
Has! Here are two shots. As I mentioned, the roller wheels are skateboard wheels. The other wheels are from the hardware store. I used longer screws with sleeves to raise them up the wheels.
Ghost Ryding 24/7
Bikes: Giant Defy with Dura Ace group, & Ksyrium SL's,Specialized Allez Shimano mixed/mashed,2011 Opus Sentiero,2008 Kona Jake the Snake,Custom built track/fixed,Stumpy Hartail,Kuwahara/ET bike.
Things you can do on a trainer...
Quoted: 38 Post(s)
BartJ, thanks for the additional photos and info. I suspect I could probably mount the wheels on the legs of the roller frame. The bumpers I could use a piece of angle iron bolted through the prexisting holes in the frame. For now, I will leave it as is but, will keep this in the back of my mind.
Quoted: 429 Post(s)
Liked 248 Times
I always enjoy watching roller videos. When someone can bunny hop off the rollers, track stand and then hop back on... now that would be impressive!
