Stuck with a Giant Contend SL1 2019
Hey guys. I bought a gaint contend SL1 2019 but the frame is to big and I cannot take it back. It's a medium size but I'm 5' 5" and now after everything I know I need a small (very bad help from the shop) its basically new done under 200miles. Can anyone suggest sites where I could swap or sell without losing to much money? Thanks
Hi Popcoin and welcome to BF. Most reputable shops want you to be happy with your purchase. The shops I deal with will allow you to exchange your new bike within 30 days of your purchase if you're unhappy with it. Even if you're no longer within that 30 day return period I would return to the shop, explain the issue, and try to exchange your bike for one that fits you properly. Even if you had to add some money to the exchange this may be a better way to go.
If you've already reached out to your bike shop and they won't help you, well first of all shame on them, secondly I guess your only other recourse would be to post it on Craigslist or Facebook marketplace, or the like. In this covid-19 world we are now living in these sales avenues may not be that active, I'm not sure though. I think if you go this route you may not get what you perceive your bike to be worth.
Lastly, I guess you could try to "make the bike fit" by trying a shorter stem. Doing this may negatively impact the handling of the bike, so there's that.
Good luck!
Tom
Good luck!
Tom
I've done so few miles on the bike I cannot lose that much money for now. I think I will make the bike fit as you said. Thanks. I didn't know it would be that had to find a 60mm gaint stem. I'm on a waiting list though.
Quoted: 1638 Post(s)
Liked 741 Times
You do not have to use a Giant stem. There are many different branded stems on the market that would be a seamless replacement. If you are looking to keep the bike as new, that's different.
nine mile skid on a ten mile ride
Hey, thanks. Does it not matter about the oil reservoir thing at the front. are they all universal?
Do you mean the cap on top of the steerer tube? There is no oil in that, it is what secures the tube, makes it look good and keep junk from falling into the fork. You just unbolt the stem caps, remove the cap on the steerer tube, slide the stem on and torque it all to specs. Plenty of YouTube stuff to help if you need it.
Bikes: 3 road steelys, 3 alu, 1 mtb, 1cx
Quoted: 20 Post(s)
Liked 22 Times
According to Giant, the hydro master cylinder can only be mounted onto the Giant Contact SL, Contact, or Connect stems.
This is probably due to the unique spacing of the 4x4mm mounting bolts. Any non Giant stem would have to have the
exact same spacing for the master cylinder to be safely mounted onto The stem. Unlikely that anything non Giant would
be compatible, so it is not a universal mounting for this system.
Liked 741 Times
I do see the reference you mention in their hydo disc brake user manual.
Looking at the geo specs of the two sizes there is very little difference that cannot be overcome by a proper stem swap. See what the dealer has available in a shorter stem that works on that bike, or make an adapter so you can mount the reservoir on the stem of your choice.
Bikes: Giant Contend SL 1 Disc
Quoted: 155 Post(s)
Liked 77 Times
I have this bike...you cannot use 3rd party stems b/c of the hydro-mech brakes. You can buy a shorter/longer stem...i actually have the M/L size bike and i went larger (one size up) basically the stem that is on the XL bike.
Good luck man.
JAG
Good luck man.
JAG
Bikes: 2021 Canyon Endurace SL8, 2019 Cannondale Topstone Sora, 2002 Giant Yukon
Quoted: 34 Post(s)
Liked 148 Times
If the latter I would do my best to not give that shop any more of my money, I hope you can support some other local bike shop.
