best bang for buck cx gravel wheel set up
Quoted: 164 Post(s)
Liked 44 Times
trying to stay under 300 USD !
EdIT : sorry , tubeless , rim brake under 300 with tires !
Quoted: 2952 Post(s)
Liked 3,106 Times
disc or rim?
tubeless?
tubeless?
Quoted: 667 Post(s)
Liked 529 Times
a year or so ago I bought a set of Mercury G3 27.5 inch wheels for I think $300 from backcountry.
Better yet I dropped a hit with my daughter so my wife bought them as a Christmas present.
Excellent wheels. Set them up with a set of Panaracer Gravel King SK 53c tires, running tubeless. Think they have White Industry hubs.
Could not be happier.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I have some Bontrager Race rims which came on my GT Zaskar LE fitted with X King tires, (Continental) I am 225LB, and i found these rims to be insanely strong. Other than doing huge jumps, nothing will bend them. The tires strike a good balance between pavement/gravel and hard pack trail use. Not so good in very loose or muddy conditions.
I've recently acquired a set of Sun rims CR18 with Shimano Deore hubs and put some Chaoyang Kestrel urban tires onto this set for pavement use. For mass produced Chinese tires, they are overall excellent performers. I'm very happy with my current setup. But these Sun rims bend much more easily than my other set. After tensioning the rear wheel, seems like it is strong enough. I still ended up getting a Suntour Suspension seatpost as a precaution.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times
I like the CR-18 rim and a deore hub. They are both somewhat out of style now, particularly with the vast array of tubeless set-ups.
Have used both of these with good longevity on road & gravel. My weight ranging from 225-250.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
Drip, Drip.
Liked 193 Times
Did you ever tension the spokes? What sort of tires did you have fitted? and what sort of bike?
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Shimano GRX wheelset. It is a great mix of weight, strength, easy service, and cost.
Prowheelbuilder.com wheelset. HplusSon Hydra rim, bitex ra12 hubs, double butted sapim spokes in the count you want, brass nipples. Another great mix of weight, strength, and cost. Hand tensioned and reliable.
Both will be around $425, so over what you want to spend. For under $300, I would look at Euro sites and velomine.com to see what is even in stock for built wheels at that pricepoint that are modern design.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
https://www.kinesisbikes.co.uk/Catal...oss/CX-DISC-v5
You could likely find them near $330 U.S. if you search around. PG
Quoted: 1455 Post(s)
Liked 1,477 Times
For $300 I'd probably look at some of the cheap/generic carbon wheels that are listed on Ebay/Amazon. I bought a set of "Superteam" wheels last year for around $325 and they've been pretty solid. They're probably 1600g and they look pretty cool.
For a bit more, you can get the GRX wheelset, which seems tough to beat from a value point of view. Not the lightest wheels around (1700g), but straight pull bladed spokes, 21.6mm internal width, tubeless ready and cup/cone bearing hubs that are super user friendly. $419
Otherwise I'd second the idea of doing a Prowheelbuilder.com build. I've played around with a few different options on there, but you can do Stans Grail with Bitex hubs and have a 1500g wheelset for around $500. There's a DT Swiss R470 rim on there that's only $51 that has 20mm internal width. I'm sure you could build that up with some Bitex hubs for $400.
Quoted: 365 Post(s)
Liked 457 Times
Tires ranged from 700x32 to 700x50. IIRC they had 35c Vittoria Randonneur Cross, 35c Road Randonneurs, 50c Schwalbe Dureme's, 32c Conti Gatorskins. I ride older steel bikes, like 80's/90's/00's, so they rode on them. 80's steel tourers are basically todays gravel bikes. The Duremes were on a Novara Safari.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12741 Post(s)
Liked 7,656 Times
100/130 QR?
$215 for these Vittoria's. This is the non-disc, but there's a disc version too. I found them easy to set up tubeless with 25mm tubeless tape.
https://www.vittoria.com/us/tactic-a...om_store=us_en
Liked 3,106 Times
I bought this wheelset and set it up tubeless for my son's CX bike. Inexpensive, bombproof. Works great. https://www.jensonusa.com/Shimano-WH...-700c-Wheelset
Quoted: 164 Post(s)
Liked 44 Times
Liked 3,106 Times
