Fitting 141mm Rear Hub on 131mm Frame
Quoted: 8 Post(s)
Hi,
Recently i just bought a hub set. The rear hub is measured 141mm and my rear frame is measured 131mm. My frame is heat treated aluminium. Difference of 10mm. Should i force in the hub? Can I skim down the nut 3mm on both sides?
Thanks
Regards,
Noraswan
Thanks
Regards,
Noraswan
Randomhead
Liked 3,664 Times
Moved here from general cycling.
141mm suggests through axle, and 130 would be quick release or bolted. So that would be a real problem for using the hubs. Can you tell us more about the hubs you bought and the make and model of the bicycle?
You can upload pictures to your gallery and we can move them here if you let us know.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
You bought the wrong hub.
Period.
=8-|
Period.
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 8 Post(s)
So is there any suggestion to be done with the current hub situation? Other than purchasing another hub.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
QR141 is the quick release version of Boost, which is now endemic on mountain bikes that are not quite expensive enough to have cartridge bearing hubs and thru axles. It’s also conveniently close to 140, which was a tandem standard. Either way it’s heavy duty.
130 is road bike standard. Usually pretty svelte.
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,102 Times
QR141 is the quick release version of Boost, which is now endemic on mountain bikes that are not quite expensive enough to have cartridge bearing hubs and thru axles. It’s also conveniently close to 140, which was a tandem standard. Either way it’s heavy duty. Would very likely have a disc mount.
130 is road bike standard. Usually pretty svelte. Would likely not have a disc mount.
Anyhow, sorry.
Anyhow, sorry.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Not really. 10mm is a big spread on an Al frame, which isn't suggested anyway, made worse by small diameter wheel which suggests short stays making it even worse.
Likes For dedhed:
Quoted: 2026 Post(s)
Liked 1,095 Times
+1. Even if you could safely spread the dropouts that far, which you can't, the chainline would be compromised. Short answer: buy the right hub.
Likes For HillRider:
Quoted: 1063 Post(s)
Liked 771 Times
Even if you cold-spread the frame, BTW-DON'T DO IT, you would still need to align the drop-outs and that's not good either. Steel with long stays a maybe, but still not a good idea.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4311 Post(s)
Liked 2,954 Times
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
putting a boost mountain bike hub on a frame designed for a non-boost chainline and a 130mm axle spacing is going to end badly. don't do it. buy the correct hub.
If you are buying another hub, why not just get the right size? It makes no sense at all to buy a 135 hub. And even if this is a freebie or something you already have, no it is not OK. That's too much to spread on an aluminum frame. I've done 126 to 130 on a steel frame but I wouldn't try on aluminum.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
OP...
Quoted: 8 Post(s)
Thanks for all the feedbacks. I will go for 130mm. I also want to ask about the aluminium frame. People keep saying the frame can crack if cold bend or force spreading. Is it the welding or rear arm frame that will crack?
Sorry if I ask a lot of stupid question. 😅
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
n00b
Quoted: 428 Post(s)
Liked 466 Times
does it matter which one cracks? Unless you have an expert welder who can heat-treat the frame, the frame (or cracked part, if it's a suspension frame) is trash once it cracks.
Likes For mack_turtle:
It's MY mountain
Liked 2,954 Times
