Anyone know an easy way to get grips off?
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
I have a 2½ year old, we bought a tricycle for her, it's vintage and I want to paint the bars, but I can't figure out how to get the grips off, I don't know if I will be able to find replacements, so I would like to keep the grips I have... Would heat from a hairdryer help?
Bikes: Schwinns, lots of them. Some Paramounts
Quoted: 18 Post(s)
Liked 7 Times
yep... If the handlebars are hollow all the way through, simply apply compressed air from a 'blow-nozzle' in one of the grip center-holes, the opposite grip should come flying off when you plug the hole on that one. Or simply stick a very small screwdriver under the edge of the grip and place a WD40 spray nozzle in there next to the screwdriver and work that spray lubricant into the underside of the grip. twist and work the lubricant in there and it will come off. And yes, you could use a hair dryer to soften the grips if you are afraid they are brittle.
Bikes: 2015 gravity bullseye monster fatbike,2013 salsa vaya. 90's diamondback MTB,84 univega.
plastic rod, and spray soapy water in between the bar and grip,twist and pull,should work.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Put an adjustable wrench on the bar and push the grips off with that. It may help to get a little water under them first.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 3464 Post(s)
Liked 2,828 Times
Time to mask and paint.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I worked a couple nails between the bar and grip, shot some WD 40 in there. Twist, twist, twist... off.
Commence to jigglin’ huh?!?!
Liked 2,828 Times
screw driver and wd-40 works everytime.
Semper fi
Semper fi
Quoted: 832 Post(s)
Liked 2,124 Times
If you can get that little red "straw" that comes with most WD-40 cans in under the grip, then a couple squirts and a little twist should get the grips off. Be sure to clean off the WD-40 so they don't slip once you reinstall them.
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
At the shop I worked at, we used to slip a very small screwdriver underneath the grip and then spray or drip very soapy water in the gap. Do this to three or four spots at different points along the grip. Then try to twist it free. If it doesn't work right away, give it a few minutes and try again. Works pretty good. Remember, water always finds a way, so let it work for you in the case.
This has never failed for me, I've used this trick on probably 40 different bikes so far. A 7/8" open end wrench will fit over most bars perfectly. Slide the wrench over the bar and whack it a few times with a hammer.
Bikes: Specialized Sirrus, Specialized Robaix, Specialized Carmel
We use a screw driver and spray bottle of alcohol to take them off and to put new ones on, they slip off nice and easy and the alcohol doesn't leave any residue.
Quoted: 90 Post(s)
Liked 137 Times
I have done it a few different ways like the rest above, a long thin screwdriver and soapy water followed by air from a blow tool will push the water in deeper and remove the grip at the same time, sometimes air all by it's self will work. I have also used Silicone spray but you must make sure to wash the grips real good if you are going to reuse them, and don't forget to wipe the bar ends with some Lacquer thinner also. I reinstall grips either using Hair Spray or rubber cement, sometimes just water will work depending on what the grip is made from, then I let them sit in the sun for awhile.
Glenn
Glenn
Quoted: 887 Post(s)
Liked 335 Times
+1
What Vonruden said. Works for me every time.
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
I do this every week at the bike coop. You can use something, like a thin screwdriver, to get under the edge of grip, pry it up a bit, and squirt in some soapy water, window cleaner, Simple Green, or the like, and start twisting the grip where you sprayed the solution. You may have to apply a second shot of solution but in no time the entire grip will loosen as the solution works its magic and breaks the adhesion of the grip to the bars.
Glenn
Glenn
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12762 Post(s)
Liked 7,675 Times
I prefer Windex or Isopropyl alcohol. The ideal tool for inserting under the grip would be a piece of spring steel about the size of a 12 gauge spoke encased in a tough plastic, perhaps Delrin, but I just get by with a broken spoke, with the end filed to a rounded profile to minimize bar scratching.
Clean bar well.
Spritz bar and inside grip with window cleaner or alcohol to help ease the new grips on.
Clean bar well.
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
And check Ebay, NOS clamps are available.
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 5 Times
As difficult as it might be to stomach, perhaps don't be cheap and just get some new grips.
What're those old grips made of? Do you want your 2 1/2 year old chewing on, licking or getting gunk from those old grips all over her hands?
Just cut the old grips off. I guarantee your daughter will not care whether the grips on her trike are period correct. Get some cloth tape and make new ones, and for cryin out loud put some streamers in the ends of the handlebars.
--Don't Panic.
--Don't Panic.
Bikes: everywhere
Liked 7,675 Times
Gotta watch bar diameter. Many trikes (and some sub-16" kids bikes) have smaller diameter grips.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
1/2" diameter kids grips are still available at any local bike shop. Should the old ones are too brittle and tear.
