Difficulty finding replacement for BB-UN300 D-NL
Old 02-28-24, 08:15 PM
Jamestyle
Liked 2 Times in 1 Post
Hello everyone,
I am new to working on my own bike so please forgive any ignorance on my part.
i am trying to find a replacement for my bottom bracket for my bianchi Torino hybrid bike.
the BB that I removed is a BB-UN300 D-NL
My bottom bracket shell is 68mm and the spindle is 123mm (I guess that means it is 122.5mm?)
he drive side of the spindle is longer than the non drive side.
does anyone know if this bottom bracket can be purchased anywhere or does anyone know of any compatible replacements?
most of the ones I see online are LL123 and D-NL
thanks in advance to anyone who can give me
some direction.
Jamestyle is offline
Old 02-28-24, 09:10 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
You should be good- From Shimano 2013-14
Bill Kapaun is offline
Old 02-28-24, 09:25 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,490 Times in 3,213 Posts
https://www.jensonusa.com/Shimano-BB...ttom-Bracket-8
SurferRosa is offline
Likes For SurferRosa:
Old 02-28-24, 09:39 PM
KCT1986
Quoted: 346 Post(s)
Liked 320 Times in 234 Posts
Originally Posted by Jamestyle
Hello everyone,
some direction.
You should be able to find this, it's still a current model from Shimano.
Just get the same model, UN300 in D-NL length with the correct BB shell width (68 or 73). Not sure of the dimensions of the LL123.
Avoid the model with E or K in the model #, those are designed for E bracket mounted front derailleur and chain case frames.
Other brand of bottom brackets of the same length would also be very similar in left &right lengths. A mm or 2 won't matter, unless your frame has clearance issues with the chainring or chainstay (very uncommon if the current BB is 'stock' on the bike.
KCT1986 is offline
Old 02-28-24, 09:40 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times in 1,020 Posts
Might as well buy a Made in Japan one if you are going through the trouble of replacing the BB.
Tange LN-3922 Bottom Bracket | (benscycle.com)
SoSmellyAir is offline
Old 02-29-24, 05:43 AM
Jamestyle
You all have been very helpful, thank you! Just ordered the correct one.
