what is the highest tooth chainring i can fit on my bike? needs a chainguard
so, i have a downtube nova folding bike. it comes with a 46T chainring, but it is welded to the cranks, so i will need to replace everything. the stock chainring has a guard on both sides
so, i tried to swap it out with a 53T shimano 600 crankset (square taper). it works perfectly, with the exception that the chain will fall off of the ring sometimes because the chain bounces when i shift or hit bumps.
i tried to put in a front derailleur on the braze on, but it will just not work. it is too stiff to allow shifting and was hitting the chain, etc. so i gave up on a front derailleur
so, i'd rather just get a high tooth chainring crankset that has a chainguard on both sides. this should keep the chain in line for me. i'd like to get something that is greater than 46T. ideas?
Only thing I can think of that has a guide on both sides, available up to 52t. You would have to find a 110BCD crankset though...
linky: https://profileracing.com/estore2/index.php?productid=47
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
so, this is a single speed bike? so there's no rear derailleur (a RD handles slack)?
so change the rear cog instead. or add a chain tensioner with the unguarded crank.
wait, so there's a front derailleur braze-on with no shifters?
so, what exactly is on this bike??
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
it has a 7 speed freewheel on the back with a rear derailluer
i was going to put a front derailluier on the bike, but it wouldn't fit into the braze on. i really have no need for a front derailluer other than keeping the chain centered on the largest front chain ring cog
i just want a chain ring cog that is larger than 46T and comes with square tapered cranks and a chain ring guard
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
Instead of using a FD for keeping your chain on the chainring. Consider using a chain keeper instead.
https://www.paulcomp.com/chainkeeper.html
There is two designs, one mounts to the down tube and the other mounts to the BB shell.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
Lance Power
Bicycle Mechanics
16
12-19-11 10:05 AM
Sebber
Mountain Biking
3
05-14-11 07:50 PM
