Inner Tubes
Inner Tubes
I have some inner tubes still in their boxes that have been on a shelf in the basement where I keep my bikes. They have been there about 5 years or so.
Question is how long do they last. I don't want to be out riding and have them with me and go to replace an inner tube because of a flat and they have gone bad one way or another. I know car tires have a date of manufacturer. I don't see anything on the boxes for the inner tubes with a date of manufacturer. Would like to be on the safe side.
Quoted: 1572 Post(s)
Liked 643 Times
I don't know but the shelf life of inner tubes is certainly longer than 5 years. I've got some boxed inner tubes in my shop that are at least 15 years old. If I needed one that size tomorrow I'd grab one without concern.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I bought the girlfriend a 1968 Schwinn Collegiate. The original tubes were still in it (marked with a production date), and they held air just fine.
I would only be concerned about a tube that had been exposed to prolonged UV or ozone, but even then it would be obvious if the tube was good or not. As long as the rubber is supple with no cracking, I would not hesitate to use any old tube.
Bikes: s-1
Quoted: 221 Post(s)
Thye last time I flipped a 50s scwhinn the original tubes held air perfectly even though the tires were rotted. I replaced them anyway because new tubes and rim strips came with the new tire set, but still, the old tubes were functional after over 60 years on the bike.
Quoted: 2281 Post(s)
Liked 1,710 Times
As long as they were in your basement away from sun & heat they should be OK. Being left outside, OTOH, will rot them quickly. 5 years is not too old for tubes as long as they don't appear cracked.
I remember when someone called me up offering a set of "brand new" tires for my pickup. I go to check them out and they were obviously not brand new, seeing as how there were plenty of tiny rocks in the tread, but had also been stored outside for some period of time. Needless to say I passed on the offer.
