Tip: removing Regina FWs from Campy Record hubs without removing axle locknut.
Quoted: 1641 Post(s)
Liked 831 Times
So, after considering buying yet another FW remover tool, because the Park tool I have does not fit over the Campy Record locknut so I cannot get at the freewheels to remove them from my wheelsets with Regina FW vane Campy Record hub combos.
Mulled over it some time, then I decided to just go for it and grind the inner wall of the Park tool with my Dremel, using a drum shaped grinding tip. Really thought I was gonna mess it up , but by being careful to apply even pressure, while rotating the tip inside the FW tool and stopping once in a while to make sure I was not grinding the walls of the tool shaft to thin at any spot....... just 15 minutes of careful grinding and testing, the tool fits over the Campy locknut and I was able to remove the Regina FW that was on the wheelsets normally. It saved cheapskate me from having to find (they don't make it anymore) and buy a thin walled Phil Wood tool that people always recommend for solving this problem common to C&Vers. I also do not have to bother pulling off the drive side half of the axle of my Phil Wood rear hub to get at the freewheel on it anymore, cause now my Park FW removal tool also fits over the axle flange on it.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Good move. A cheapskate like me never bought a Dremel.
Real cyclists use toe clips.
jimmuller
jimmuller
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Phil wood tool work just fine.
Death fork? Naaaah!!
+1 for Phil.
Top
Top
Liked 831 Times
Never bought a Dremel either, ...........the Dremel I have was just inherited from my older brother......
It's over 25 yeaars old but still works good after many years of use. Very basic model from the mid 80's, but at least it has a rheostat for speed control....
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 2588 Post(s)
Liked 4,824 Times
Hmmm...I can see this from both sides. The Dremel-guy in me would do this in a pinch, but I'd still like the unmolested, original Phil or Zeus removal tool. The early thin-wall removers had a habit of caving in over time; milling one out with a sanding cuff going by nothing more accurate than feel would perhaps duplicate the probability of failure.
So, the DIY approach for a save-the-day one and well-spent-money on the real deal for the to be relied upon one. I've learned over time (with a corresponding amount of damaged fasteners) that you use the best tool you can find. It just makes sense.
DD
DD
Quoted: 1858 Post(s)
Liked 664 Times
Set up as 5 speed, or wider? From bitd I'm sure I never removed a locknut unless for an overhaul.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Dremel tools pay for them selves, and no self respecting man would pass up buying a new or even used tool. I'm with DD on this one, get the correct, quality tool, and them enjoy its being right at hand, knowing it will do what is needed.
Bill
Bill
Semper Fi, USMC, 1975-1977
Quoted: 78 Post(s)
Liked 30 Times
Or you can use a later lock nut which has a smaller OD
Liked 831 Times
But Noooo! Those later nuts are not period correct
As for my old Dremel tool, I had just be hundreds of projects done on it already. From the shorty projects like this last one or literally boilers of cutting and grinding metal and plastic to make project parts for my car and motorcycles. Lately, the switch/speed control wheel had been falling off when I use it, and there sometimes seem to he an intermittent loose connection within the plug wires where it goes into the tool so I'm trying to convince myself It's a safety issue that could justify finally replacing it with the really slick model 4300 Dremel kit I had been eyeing during my last few trips to the hardware store..... but my wallet still does not want to open up to that idea...
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I remember overhauling one rear hub where I decided to grind the corners off of the locknut(s) so that the tool would slip over them in the future, whenever I wanted to pull the freewheel.
I didn't know that later hubs had reduced-diameter nuts. Was it just that the corners on those were trimmed, or did they use a smaller size across the flats?
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Another vote for the Dremel, particularly the multi-speed variety, as opposed to the single-speed (gave that to one of my sons after he kept borrowing the multi-speed one). I have a couple of the big assorted attachment kits, including sanders, grinders, cutoff wheels, etc. Mine gets a fair amount of use.
Yoyo2012
Classic & Vintage
12
11-04-17 08:44 AM
Roll-Monroe-Co
Classic & Vintage
13
04-24-13 12:20 PM
