Nuovo Record Rear Derailleur with Roadlink?
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I have a Nuovo Record rear derailleur from a 1973 bike that I am restoring. Velobase shows that its max cog and chain wrap sizes are both 26T. What can I expect the max sizes to be if the derailleur is used with a Roadlink? Thanks in advance!
"https://www.velobase.com/ViewComponent.aspx?ID=D8DE34D4-C66F-4C8A-AF5B-0EF99D40F702&Enum=108&AbsPos=62"
I am running mine on 28T cogs on 2 bikes without issue. Not sure about the roadlink but as a short cage derailleur you are going to be constrained by the chain wrap. Even if you can fit a 32 in the back unless you're running a very close ratio chainring setup your chain capacity just wont be taken up.
Likes For Narhay:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 640 Times
Not to increase capacity, but I've been wondering for a while if one could use a NR with a Roadlink, filed down to allow the RD to pivot forward with the parallelogram more horizontal to make the geometry more Crane-esque.... would it word and would it improve performance?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 1627 Post(s)
Liked 630 Times
I've used a Pat 72 NR with a 32T cog. That was with NR 52/42 up front. Big/big was super iffy, but everything else was fine. Depends on the chain length, position in the dropouts, and of course the length of the hanger. I've got one of those road link hangers but haven't tried it yet.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
Liked 630 Times
IIRC, it was a SunTour Perfect 14-32 six speed freewheel.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
I'm wondering if a NR RD + Roadlink + 7sp 14-32 will work
Liked 630 Times
Maybe. What's the chainset up front look like? How confident at determining chain length are you? How much leeway do you have on your drop outs?
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Super Record Cages on a Nuovo Record derailleur will shift 28T with ease.
Likes For Michael Angelo:
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
42/52 rings, good at links, Campy horizontal dropouts. - I am willing and able to give it a try, but am wondering if anyone has done this successfully. I could go 30 max at back or a different RD.
Quoted: 987 Post(s)
Liked 640 Times
This AM's eBay asking prices on a Rally are $200 to $450, ouch.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Ive got one for a lot less if you want.... What the???? he's right! posting mine now. Less to BF members...
I seem to have lost what little mind I had left before this all started.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Regular NR and with horizontal dropouts can handle 14-32t Ultra-6 using 48-42 chainrings. All shifts are good and everything looks PROPER. Axle position is critical.
The Road Link is going to increase the chain gap over the smaller cogs and not in a good way, especially using modern, flexible chains.
Swinging the NR forward to mimic the Crane won't work very well because of the absence of the dropped knuckle (you will lose the ability to clear such a large cog as it swings forward). The Rally with dropped knuckle was made for the job to accommodate a wider gearing range.
Likes For dddd:
Liked 630 Times
I think 30T should be relatively easy, based on my experience with 32T. But it's hard to guess about any other possible differences in the setup I did with the stuff you're working with. My advice is just give it a try. First without the Roadlink.
Quoted: 874 Post(s)
Liked 2,291 Times
I was stoked to get a 14/28 freewheel working on my 1972 ItalVega for last years Eroica California event. With a pat 72 NR dereailleur and 52/41 front rings everything is happy. I showed Wes who at the time was helping with the event and he told me 32 is possible if you remove the axel stop screws and pull the wheel as far back as you can. I have not tried it but I am tempted as I live on a hill and am now running 28's on a couple of my bikes. The other bike running a 28 just got switched to a patent 82 Super Record and it works perfectly , big to big , no problem.
Liked 1,296 Times
Quoted: 3811 Post(s)
Liked 6,711 Times
Just go Shimano Deore/XT/XTR and close your eyes when shifting.
Likes For nlerner:
Quoted: 987 Post(s)
Liked 640 Times
Hmm, wouldn't the RoadLink emulate a dropped knuckle, if ground down to permit the rotation? That said, the RoadLink does not look long enough; I thought they used to make (or someone did) longer ones. I'm tempted to try it, just for fun, but unlike the OP my largest cog is 24T "your results may vary".
Liked 1,296 Times
If you were to grind the stop on a RoadLink that far, I don't think that there would be any metal left to act as a stop.
Quoted: 938 Post(s)
Liked 2,944 Times
I had a Pat. 78 shifting on a Shimano 7-speed 28 without breaking a sweat. I'm sure 30 would have worked, maybe 32 with positive vibes...
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
A while back, I saw a way too tall for me Eddy Merckx bike listed for $750 locally. I was trying to justify buying/flipping it just for its Rally rear mech. That's the only way I'll likely get my hands on one.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Quoted: 987 Post(s)
Liked 640 Times
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
i'm going to attempt an '83 super record RD with 16-30 regina 5 speed with 42/52 out front, so when my frame gets back from groodys in a few weeks i'll see wazzup i have a roadlink on hand, but i think by tweeking the chain length i can make it work sans link.
