29er Revolution Article & Review
Bikes: Trek 4900
My LBS put out this interesting article about the history and benefits of the 29er. Thought some of you might find it interesting.
https://bicyclesportshop.com/page.cfm?pageId=1522
Old School Rad
Bikes: Blur LT
Hmmmmm, I can't find any benefits to a29r.
Like a circus monkey on a stolen Harley......
I just bought my Fisher Rig the other day and have been out on it twice. I must say the ride is sweet! I'm not going to brag it up just because I have one, but it appears to be working for me just fine. I will say it is taking a bit to adjust to single speed, but that will just take time and many rides. As far as the 29" wheels go, I would say that I did find it a bit different in the handling area when dealing with technical and slow parts of trails. I will say that I feel like I'm floating on that bike. Part of it being able to use lower tire pressures and also probably the geometry of the bike. I would definitely buy another one, and probably will look at the new carbon Fisher single speed in a couple years.
Guest
Posts: n/a
Quoted: Post(s)
After getting my MotoB Ti, I've decided that my 29'er will be my "camping bike". Heck, I may take it to the trails tomorrow. But it's so hard to go from that tank to my ultra quick, fast climbing, geared 26".
Bikes: 08 Stumpjumper FSR Expert, 02 Litespeed Tuscany, 04 Specialized S-Works Epic
Have you actually ridden one??
I just bought a niner HT. Now, I'm not a rabid "you gotta go niner" type, but I have found a couple of definite advantages.
1. Before I went FS, I was able to ride about an hour on my 26HT before by lower back cried uncle. I've been 2 1/2 hours on this one with no issues whatsoever.
2. Where I had, say, 2 lines through a tricky section before, I now have 3 or 4 because of the way the wheels roll over things.
3. Baby heads and loose boulders are easier.
4. Sand? I'm fairly big guy and sand would grab my front wheel no matter how I weighted (or unweighted) it. With the big wheels, I just roll through even the deepest sand with only minimal grabs of the front wheel.
5. I don't find it to be slower accelerating than my small wheels. Then again, I'm a slow rider, so probably wouldn't notice this anyway. I do climb faster now... but that might be the HT as much or more than the big wheels.
6. Switchbacks seem easier on the niner. Is it the enthusiasm of a new bike or the stability? Since the newness is wearing off and the switchbacks are still easier, I'm going with the stability.
7. I feel more a part of the bike than on my 26er. i felt this before I read about greater BB drops, placing you lower on/in the bike and effectively lowering your CG, but it makes sense and most definately makes it feel like I'm ore a part of the bike than just sitting on top of it.
Am I ready to ditch my SJ FSR for a 29er FS bike? No, not yet. But I will be testing out some FS niners to see if that may be the way to go for me. I haven't found anything yet that would be too tight or technical for a 29er with good geometry.
Give one a try, you might surprise yourself!!
Old School Rad
Bikes: Blur LT
Yes I've spent some time on more that one and I hated the freakin' things. I can see where they would be great to ride gravel roads but I'll take my small frame 26r for fun trail riding. So I guess I should rephrase that.... for me they would be OK on gravel roads.
Pint-Sized Gnar Shredder
Bikes: '09 Jamis Komodo, '09 Mirraco Blend One, '08 Cervelo P2C, '08 Specialized Ruby Elite, '07 Yeti AS-R SL, '07 DMR Drone
I haven't ridden a 29er, but I'm able to take much sharper turns on my 24" than my 26". I assumed it was because I was on a more agile bike with a shorter wheelbase. However, I would assume that the longer wheelbase on the 29er is what's giving you that added stability. Interesting.
astrositupataphysicyclist
Bikes: too many now
someone on the trail the other day had a 29 on the front...and a 26 on the back...
i have yet to try one, but i believe what's been said about the advantages. to me, the disadvantage is the weight and, heck, SIZE! i like the response of a 26...
A similar geometry FS solved the problem. Maybe i could have found a better fitting HT... I'm not sure. But this 29er is very, very comfortable.
Pokemon Master
Well, that's possible. I was still pretty new, but did research on the bike before I bought it. Also, it wasn't a cramped, not feeling right back pain, but more that the trail vibrations felt like they were going right up the seat stays into my back.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Must . . . resist . . . urge to . . . BAN . . .this . . . user . . . ..
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Interesting article and I learned something new ... a 29er actually uses the 700c road bike wheel adapted to fit.
The "standard" off road sized wheel was 26" for years. It was adopted by the pioneers of modern, California style off roading as a reasonably tough, cheap, and conveniently available choice. The 26" wheel worked out alright from a standpoint of availability, price, and toughness, but the early California pioneers of the MTB didn't have a research lab to see what would make the optimum wheel size for off road adventures. They made their choice based on convenience and product availability.
The term "29er" was born in 2001 with the release of the first mass production big wheeled mountain bikes, Gary Fisher's "Two Niner." However, the concept of the big wheeled off-road bike traces back to the 1980's and the basic technology involved dates back even further. While some may think that a 29er involves a new rim size, it actually utilizes a 700c size rim. While this wheel size had been used on road bikes for decades, it took a number of innovations to make the 700c applicable to a true mountain bike.
Hmmm... maybe I didn't express it right.
I guess that's a better way of putting it. It actually does make sense that a 29er wouldn't have an overall lower CG and in fact, with the bigger tires, it would be logical for it to be a bit higher or, if the geometry puts the rider lower on/in the bike, the same.
Originally Posted by https://bicyclesportshop.com/page.cfm?pageId=1522
In addition, the rider on a 29ers wheel bike has a lower center of gravity in relationship to the wheel’s axle. Think of it as riding “in” the bike, instead of on top of the bike.
Guest
Posts: n/a
Quoted: Post(s)
Official Website Waterboy
Bikes: a lot
I'm gonna ride with a guy this week on his 29er, he's in way better shape, and know's the subtle nuances in the trail way better than me. But, I'm pretty confident that I can roll anything he can roll, I can Climb anything he can climb, I can go down anything he can go down, and in the end i'll be right beside him when we reach the parking lot.
Does that make a 26 better? or a 29 better?
Guest
Posts: n/a
Quoted: Post(s)
Alright, I'm back. After not riding that thing for a month, I feel I can give a fair assessment.
Here's the deal: full rigid (full riggie?), SS, cheapest 29'er on planet earth (MB Outcast 29'er), low-tech brakes, cheapo cheapo cheapo. Oh, and my grips were doing full 360's on my bars. I hate non-locking grips on MTB's. So set aside the lack of travel, lack of gears and slipping grips for a sec.
Now, I don't know if it's the efficiency on the SS, if it's all in my head, or I just had POWAH today, but the sucker seemed easy to ride, climbing and rolling was a little better. Standing up and climbing ruled and I can outright feel the difference in lower rolling resistance. It felt like I had a nice wind blowing from behind and pushing; it just rolled better.
The downside to the 29er is you really can't turn the thing as quickly as the 26" and I did test the "29'er ability to roll over things easier" and I can't really say there is a night and day difference... maybe because my 26" has a suspension fork and my 29'er is rigid.
Eventually I'd like to replace that frame with a Karate Monkey and a nice suspension fork, still keeping it a SS.
I don't think I'd replace my 26" with a heavier 29'er, but it sure is nice to have as a back-up or a change of pace. I liken it to riding my road bike and riding my fixed gear.
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
Having switched to a Niner EMD9 in May, I will never go back to small wheels again.
For my style of riding, the Niner corners and turns well enough - but the big wheels have ratcheted up my ability to clear technical sections by one or two whole notches. I can now easily clear stuff that would make me dab or go endo on a 26er. The only downside is that on steep extended climbs, I could use smaller gearing (I am talking a 30km ride up from 11,000 to 17,000ft, for example) - and the big wheels are notably harder to re-start if you stall on a slope.
V.
V.
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
They aren't for everyone.
https://forums.mtbr.com/showthread.php?t=491856
Some like them, some don't. I ride with a couple people who love them, and a couple others like me who've tried them and disliked them. The 29er zealot types that try to push them on others and deride 26" stuff just seem like *******s to me, and would probably be so no matter what they ride. I don't get why they get all pissy about someone else not digging their wheel size.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I am not a mountain biker, but recently helped my son do the research on a bike for him. He's 6'1" and about 220 lbs. The shop we went to said a 29er would be a good bet for him. The reading we did said that they provide some of the benefits of a full suspension 26 bike with less complexity at a lower weight because of the longer wheelbase and larger diameter wheels. The wheels also provide for better stability and traction because of higher angular momentum and footprint. The drawbacks are higher weight and slower turning compared for a front-suspension-only 26.
