11-34T cassette?
Bikes: Cannondale Synapse
Quoted: 5 Post(s)
11-34T cassette?
I'm new to road bikes and ride hilly terrain. I encounter over 9% grades on my daily rides which slow me down to around 60 rpm. I definitely want another gear.
I have a Cannondale Synapse Shimano Ultegra w/ 50/34 front chain rings and 11-32 rear cassette.
Does anyone make an 11-34 cassette?
Would I need a new derailleur cage if I make the change?
Would I need to change any adjustments besides reducing the cable tension?
Am I just being a wuss and should just man up and ride what I have?
Depends on the derailleur. The longer the cage, the more tooth spread you can handle. My older Campy mid sized cage could not quite handle that gearing, but a long cage or a more modern Mid cage could.
You will probably have to give up the 11, and go 13-36
Or hit the gym and do leg work until the current gearing feels fine.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
That essentially buys you half of a gear step over your 11-32.
I put an 11-36 SRAM cassette on my "off-road" wheel-set for my Ultegra Di2 bike, and cranked in the B-screw. Works reasonably well.
I also put a 46/30T crank on. (There is a thread on this in the 50+ forum with a lot of options listed.)
Each of these two buys you a full lower gear; the crank shaves one off of the top.
You should ride whatever gearing you want without apology or HTFU type "advice" from people who sneer. They have no idea what your needs are, or what your terrain is like. (Having said that, a 30T in front with a 36T in the cassette is only useful to me off-road, where standing to climb a steep hill isn't an option).
Every one is different. Get the gears YOU need.
EDIT: As mentioned above :-)
An other option is a "road link" and a 11-40 cassette.
Mostly on topic- with the new 11-34, can the Dura Ace RD9000 handle this capacity? I know it will for sure the 32, but I have some 10s wheels I'd like to utilize and this cassette option would help (when it's fully available).
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The CS-HG800-11 is the new Ultegra 11-speed cassette with 34 tooth sprocket.The SRAM PG-1170 11-speed cassette which goes up to 36 teeth.I'm using the SRAM 11-36 cassette. The rest of the bike is Ultegra 6870 Di2 with GS rear derailleur. The 36 tooth sprocket is not supported by Shimano but it works fine on my particular bike. The only adjustment needed was turning the rear derailleur B screw in quite a bit and sizing the chain properly. It shifts with no problem whatsoever and I cross chain the crud out of it.
Note that I said it works on my bike. I'm not claiming that it will work on any other bike but lots of guys are using it.
-Tim-
-Tim-
-Tim-
-Tim-
Awesome. Sounds like it may be worth a try with what I have! I can just run my extra 11sp cassette minus a cog until the R8000 one is readily available.
OP- isn't this place great?
Expired Member
Quoted: 3666 Post(s)
Liked 5,420 Times
I don't really see anything wrong with a 60 cadence on a 9% grade.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
My preferred climbing cadence is ~83 on long grades. Yesterday I did 2600' followed immediately by 2900'. 83 was perfect for me, though sometimes it was down as low as 78 or up to 90, depending on gear. Legs didn't get really tired during though they are tired today. I know stronger climbers than I who run ~95.
Results matter
Results matter
Chases Dogs for Sport
Yep, those who don't see anything wrong with climbing at a 60 cadence either don't climb long climbs or haven't done it for very long. Knees aren't built for doing that very much.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Depends on what kind of 9% it is in my opinion. I live in a fairly hilly area, but 9% honestly might be .2 miles, usually less, and I have to agree with Shelbyfv, what's wrong with a 60 cadence on a short section of 9%.
Had I a mile of true 9% average grade no question I'd gear it way down, spin up and go slower than on these punchy grades. It's more about horses for courses though than selecting a cadence.
Liked 1,938 Times
Results matter
Results matter
Quoted: 147 Post(s)
Liked 8 Times
Typically, you go to an MTB rear derailleur... they will handle an alpine-range cassette. Since its marketing, you can switch over to a full MTB drivetrain on a road bike with no problems.
Expired Member
Liked 5,420 Times
I'd love to be able to spin up all the hills but it's not happening unless I go to a 40t pie plate or something. My hills are short and from 9 or 10% to about 20% I just ride as if I'm climbing stairs, one foot at a time. I'm not going to ride the few hills over 20% anymore, got dizzy the last time and that was kind of disturbing. I'm not really advocating this, spinning is obviously better, but it's not the end of the world. BTW, Flash- you may know the roads I ride, Williamson and Maury counties. Up and down but no really long grades.
Bikes: Giant Defy Advanced 2, S-Works Camber, Eddy Merckx Ti-Ax
Quoted: 25 Post(s)
This.
I'm a spinner, and fairly fit. I routinely will pedal my way up gradients less than 9% using a 34x28 or even 34x32 at a high RPM.
I can, and sometimes do, stand and grind a bigger gear at a lower RPM up a short rise, but it's not a common way I climb.
There's nothing manly about trying to push a monster gear up a climb and suffering, or worse, injuring your knees, or back (wait until you're older). If I ever ride something like Mt. Washington, I'm going to swap the front ring on my bike for something like a 26. Yes, a 26x32 will be first gear. I may look like a sewing machine as I go up that thing, and I couldn't care less if other people think I'm a wuss doing it.
I use the wolftooth road link on my ultegra setup. I have the ultegra long cage RD and and 11-36 cassette and it works perfectly. The road link attaches to your RD hanger and basically drops your rear mech about an inch, giving you room for a larger cassette. You need the long cage RD because it has to be able to pick up the slack of the longer chain needed for the larger cogs. Basically the whole package of new RD, chain, and road link cost me a total of about $150. I still have my 53/39 up front, which gives me the best of both worlds. I can spin up hill in a gear that is very close to a compact with a 32T, and still crank it in 53/11 if I need to.
Bikes: Litespeed Bella Novara Pulse
About 4 weeks ago I put shorter crank arms on my bike because I'm really short. Several people had mentioned that shorter crank arms are easier to spin, and this was true for me. My hip flexor pain has gone away completely and I'm able to keep a higher cadence. I picked Rotor 3d 150mm cranks because my inseam is only 27 inches from crotch to floor. A couple people who are 5'10 and up have reported good results with 165mm cranks.
Since I had the Rotor crank arms, I was able to get these 46/30 chainrings. https://www.bikerumor.com/2016/10/25...-plus-pricing/ It's low gearing for days with my 11-28 cassette, and I don't miss the 50-11 combination because it never really got used.
Lovely Bike has sub 1:1 gearing with this hybrid sram/campy setup. https://lovelybike.blogspot.com/2013/...ampagnolo.html
Quoted: 5 Post(s)
Thanks so much for the replies gents. It's all really valuable to me because I don't have any perspective yet - including about RPMs. I'm vacillating now between an SRAM PG-1170 11-36T cassette and a Shimano Deore XT M8000 11-40T cassette using the road link drop down
Would a Shimano 105 5800 HG601 11 Speed 116 tooth chain likely be long enough for the 11-36 cassette or the 11-40 w/ the road link?
If not, do I need to buy two chains?
I'm wondering if the space between gears for the 11-40T would be a jump in cadence.
Bikes: Nashbar Road
Liked 341 Times
Yes, not having big jumps in cadence is the whole point of closer spaced cassettes. It is somewhat minimized there because most of the jump with a 36 or even 40 is between the last two or three cogs and the bailout. But you will have wider gaps.
Quoted: 127 Post(s)
The chain should be long enough. Just don't cross chain. The better solution for a cassette that big is to get an SLX/XT/XTR sgs rear derailleur in combination with the Wolftooth Tanpan. Yes it costs more, but you won't have to worry about wrap capacity or snapping off the derailleur.
Quoted: 5 Post(s)
Thanks a lot guys. I decided to get the 11-36 cassette because TimothyH said he's using that successfully w/ a Shimano Di2 derailleur. Got the 116 tooth chain which should be long enough. Thanks to everyone for all the help.
- Soli Deo Gloria -
Liked 736 Times
Please get it because you are willing to try it, because you are willing to see for yourself whether it works or not.
You need to pay very close attention to how you size your chain. Too tight and the rear derailleur might rip right off.
By all means however, please let us know how it works.
-Tim-
Farmer tan
On the other hand, since you're just starting out, you'll get stronger and lighter in a month or two if you keep riding.
